Alignment settings
Old Feb 26, 2006 | 09:28 PM
evo8dad's Avatar
Alignment settings
For those os you who are running coilovers and compete in autox event as well as track days, what type of alignment settings are you running? I also drive my CT9A daily so, I don't want something super aggressive.
I have been thinking about 1/16th toe out in the fron and zero in the rear. Camber I want to set a little negative in the rear and add -1 degree in the front. I would then change the front camber setting to about -2 or -2.5 degrees at the event via camber plates, although I am not sure what that would do to my toe setting? What about caster? OEM settings or something else?
Old Mar 1, 2006 | 06:34 PM
zze86's Avatar
bump, I would like to hear some inut as well...
Old Mar 2, 2006 | 03:03 AM
mrbkkt1's Avatar
anyone know what the stock alignment specs are? mine must be a little in cause my insides of my tire are toast(16k miles)
Old Mar 2, 2006 | 06:02 AM
djtmotorsports's Avatar
On my daily driver/track day car I use:
0 toe front and rear
-2.5° camber front
-1.3° camber rear
Darin
Old Mar 2, 2006 | 07:15 AM
kekek's Avatar
I run the following and it isn't too killer on tires.
Front
-2.7 deg camber
zero toe
Rear
-1.8 deg camber
zero toe
I like the additional rear camber b/c I tend to throw the car a little in transitions and I feel it helps to "catch" the car. If you find the car is understeering steady state you can always take some rear camber out. Adding some toe for autox would be nice but will ruin the tires when doing highway mileage. Caster is not adjustable. You can try and shift your camber plates in the holes, but that only allows a minimal gain/loss.
Old Mar 2, 2006 | 01:53 PM
mayhem's Avatar
Difficult to find that alignment setting for open track days AND autox. Camber would be up to you, but of course I would suggest getting as much as you can on the front (past -2 and you get bad tire wear) and -1 ~-1.5 in the rear.
Toe is what will make the difference for the two different track options. I don't autox so I prefer zero toe in front and just a hair of toe-in in the rear. Autox you might consider toe out in the rear. Or just settle with 0 toe in the rear.
I think there's some experimentation still to be done with front toe changes on the track. Might be more up to your style and what "feels" right.
Old Mar 3, 2006 | 12:33 PM
bdiddy's Avatar
Changing the camber at the track will greatly change the toe on these cars, I wouldn't recommend it unless you are going to correct the toe settings. One way to do this quickly is to find the correct track toe/camber setting and mark it on camber plates and thread on the rod, and do the same for street setting. It will be close enough and quick. I've done this on several cars, but don't just change the camber....the geometry of the steering box in relation to the suspension is such that the toe changes DRAMATICALLY when you change the camber. Just an FYI.
Old Mar 3, 2006 | 02:05 PM
evo8dad's Avatar
Thanks for the info. I will be doing the alignment tomorrow and will get some settings for both street and race so that I can change between the two at races.
namwens
Nov 4, 2009 01:13 PM
idriveanevo
11
Jun 16, 2009 09:45 AM
andber
May 28, 2007 10:16 PM
EVO8LTW
37
Sep 27, 2004 09:23 AM
propellerhead
May 11, 2004 11:27 AM
