tire rubbing?
The rears are fine. I just have a problem with the fronts. I have stock hight in the rear and espelier springs in the front, that lower it about 1" for that even look. I don't really want to put the stock springs back in. Does anybody know if a small spacer will work in the front? I get rubbing when I turn all the way to one side.
Originally Posted by crow
I am running a CE28N 17 x 8.5 +30 with 245/45r17 and I am getting rubbing at full lock in both directions. Does anybody know what I can do to fix this?
the only sizes you should ever run on an evo 17 255 40, , 245 40, 275 40, 18 255 35 265 35. that's it. if you want 285s then consult your local suspension guru cuz you're shavin' some stuff or spacing ridiculously.
if you want to run thin tires for no good reaso you can try some of the skinnier tires in 35 profile but i'd say that's a waste too.
I spoke to sveral people and they all told me that 245/45 are fine. I wanted to go with a 255/40 but they told me they would not work unless it was a +35 offset. I looked at the threads and nobody says they wont work.
TheMasongtre
11
Mar 22, 2023 04:01 AM
jdparadee
Mar 17, 2009 04:54 PM
LRD
18
Jan 24, 2009 03:34 PM
