coilovers 12kg?
Old Apr 10, 2006 | 12:44 PM
forbidden color's Avatar
coilovers 12kg?
front and back 12kg coilovers for Evo's. Who's got it?
Just wanted to know.
Old Apr 10, 2006 | 12:45 PM
nevermind, found it. Tein type RA.
Old Apr 10, 2006 | 06:00 PM
LordEvoIX's Avatar
HKS HiperMax Pro PFR :
12KG Front (200mm spring)
12KG Rear (170mm spring)
Old Apr 11, 2006 | 04:27 AM
kekek's Avatar
understeer! got that right now on my RA's.
Old Apr 11, 2006 | 11:52 AM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
I have 12kg Springs front and rear on my Bridgestone NPG Zeromaters
Old Apr 11, 2006 | 09:52 PM
Stop&TurnFreak's Avatar
Actually, understeer goes away with the proper sways, and underbracing in the rear. I am going to 14k and 16k accordingly....
Old Apr 12, 2006 | 04:58 AM
kekek's Avatar
I'm not a fan of sways for autox, hurts transitions too much. Use of springs only allows more droop and helps keep the inside rear down too. Interesting though, those rates are about what I want to switch to. I had 10k frt and 12k rr and the balance was great, unfortunately its too soft for my current tire setup and the 12k frt & rr just is too pushy. Only real problem is my RA's would need a revalve and I don't feel like sending them out. Have you had your Flex's reworked for the high rates?
Old Apr 12, 2006 | 11:12 AM
Maybe......If you want it to stop pushing, just tighten up the rear, not necessarily sways, bracing works good, and will allow the car to rotate easier.
Hiboost
75
Dec 4, 2019 05:09 PM
LCS
Jun 15, 2016 02:26 PM
Clue4488
47
Nov 21, 2009 07:58 AM
500whp.com
Jun 5, 2006 11:10 AM
evoPirate
11
Jan 26, 2005 01:30 PM
