Advan A046 = Directional?
They are direcitonal but not asymetric. Which means you can have the tires from the right switched with the tires the left, but you can not take the entire rim from the right and bolt in onto the left.... got it?
^ No, i'm confused. But instead of explaining it, do i just need to buy new tires?
Edit: Wait wait wait, i think i get it. I can swap the tires onto the other side because they will still be going the right direction, and they will wear the other side, right?
Yeah inside edge.
F'ing Les Schwab (sp?) won't do it "because we don't carry those tires." I'm like, i don't care.. JUST DO IT, I WILL PAY YOU.
Bastards...
Bastards...
before you do this a lot of times tires with a lot of inside edge wear, the tire will start seperating. you should ask your local tire dealer if they see any of that. also check for steel belts coming through.
How many miles are on the tires currently?
Originally Posted by WW3900
wow. i'm surprised they won't. they usually would. the guy you talked to must be having a bad day.
Originally Posted by Neal @tirerack
check out one of our installers in your area. they should be able to help
THANKS GUYS!
