Storing winter wheels.
Just wondering if I should let the air out of the tires or just leave as is.
I just ordered some rims and tires and is wondering if there is any right or
wrong way to put away my winter wheels.
You can leave as is. Here are some tips on storing tires from our Tech Center
Since heat and exposure to the elements are the primary factors that influence a tire's aging process, drivers can prolong their tire's life by minimizing their impact. Here are some tips for storing tires that will not be used continuously.
• Don't store a vehicle with weight on its tires for extended periods of time. Long-term inactivity is more harmful to tires than short weekly drives that flex the tires and help maintain oil dispersion within the rubber compounds.
• DO NOT APPLY ANY TIRE DRESSINGS. Tire compounds are formulated to resist ozone cracking or weather checking.
• Keep the tires out of direct sunlight. The sun's ultraviolet rays and radiant heat are detrimental to rubber. We have used a pyrometer to measure tires that were simply sitting in direct sunlight on a parked vehicle. Surprisingly those tires' temperatures were 135° Fahrenheit on their surface.
• Place each tire in its own large, opaque, airtight plastic bag (such as lawn and garden bags) for storing. Avoid allowing any moisture and remove as much air as practical (some drivers even use a vacuum cleaner to draw out as much as possible). Close the bag tightly and tape it shut. This places the tire in its own personal mini-atmosphere to help reduce oil evaporation.
• If you choose not to store white letter or white stripe tires in plastic bags, it is important they be stored or stacked "white-to-white" and "black-to-black" to prevent staining the white rubber. The black rubbers used on the inside and outside sidewalls of white letter and white stripe tires are compounded differently. The black sidewall uses standard rubber, while the tire's "white" side uses a top layer of non-staining black rubber over the white to prevent oils in the tire from migrating into the exposed white rubber and discoloring it. Stacking all tires "white sidewall up" will allow the oils from the black sidewall to migrate into the white rubber.
• Place the tires in a cool, dry location. It is better to place tires in a dry basement than outdoors or in a hot garage or attic. The basement temperatures will tend to remain cooler and more stable, while outdoor, garage and attic temperatures will often become hot and face daily fluctuations in temperature.
• Keep the tires away from sources of ozone. Electric motors that use contact brushes generate ozone. Keep your tires away from the furnace, sump pump, etc.
While tires will age somewhat regardless of what precautions are taken, these procedures will help slow the process compared to not doing anything.
CaptainQuickie
24
Oct 31, 2012 08:29 AM
cnj4ever
13
Sep 4, 2009 06:24 PM
shinobee1
164
Dec 25, 2007 02:57 PM
