Endless CCRG installed
In my initial 100miles of use the only thing I can say is:
OMG, this thing is freaking LOUD coming to a stop. SQUEEEEEEEEEEEEEEEEEECK.
Everybody look at me imagining that my brakes are completely worn or go and change this S****T pads!!!!!!!!!!
Unacceptable!!!
Three options:
1. Drive a little bit more to see if after the bed-in time the noise goes away
2. Put Permatex Cooper anti-seize compound (2 weeks to arrive in my hands)
3. Uninstall the CCRG and intall the SSM (next week)
Unacceptable!!!
Three options:
Everybody look at me imagining that my brakes is completely worn or go and change this S****T pads!!!!!!!!!!
Unacceptable!!!
Three options:
1. Drive a little bit more to see if after the bed-in time the noise comes away
Unacceptable!!!
Three options:
I will try Permatex stuff.
Which one I have to buy? Where to use?
*Silicone Hi Temp lube
http://www.permatex.com/products/aut...ne_Formula.htm
*COPPER anti seize compound
http://www.permatex.com/products/aut...ubricant_b.htm
uhm... with a pad that hard you should expect a ton of rotor wear if you're running them cold too. i'm under the impression that the ccrg is the highest level of endless pads... i know with perfomance friction pf97 and ferodo ds3000 they wear the **** out of your rotors in no time.
After 1000miles of use the brakes are quieter. No more squeeeck. I did not touch the brakes.
No steering wheel vibration with a spirited downhill drive
No steering wheel vibration braking from 138mph
I will keep you updated... with some 150+mph hard braking at the track
KOOLER
Jul 28, 2016 05:10 PM
A-SPEC
Evo 'For Sale' Suspension / Brakes / Handling
Dec 16, 2008 12:24 PM
DrivelineSales
58
Nov 24, 2008 12:30 PM
k270kmh
Aug 10, 2006 03:21 PM
