No more cold air!!
No more cold air!!
So i turned on my air conditioner today and after 5 mins I was still getting hot air. The last time i used it was about 2 weeks ago and it worked fine. Any basic things i can check before bringing it in?
Maybe you got a hole in a evaporator and the R134A leaked out... I would check if you have gas in the system. There should be a nipple valve somewhere to see if it's charged. Depress it with a screw driver (similar to a tire valve) and if you hear a hiss its charged, if you don't you got a leak somewhere.
IIRC look on the passenger side of the engine bay. There is a silver line running along the fender. There is a blue screw on cap in the valve. Take off the cap, and just lightly blip the valve and see if you hear a hiss come out.
Look on the right for the silver line with blue cap.
well, i unscrewed the cap and pushed on the valve......... nothing. I remember last week after i got out of the car and was doing something near the front, i thought i heard what i know now could have, and probably was a leak. It was coming from around the passenger side of the intercooler and it seems that's right where that line runs. Is there any way for me to fill it back up and test it to find the leak? also.... what exactly is that gas for?
I wouldn't bother finding the leak since you should be covered under warranty for that sorta thing. Let Mitsu fix it.
It pretty simple to charge it, just follow the directions for a particular charging kit.
There are 2 ports typically a high side and a low side, they are covered by caps. You can buy off the shelf charging kits, but I would not do it. They come with meters with empty to full. The problem is you never know exactly how much you are putting in, and if you overcharge the system you can damage it. When you modded the car did you touch any of the AC lines?
