Beatrush Member Bars Install
I have a set of these I'm going to install. I know how they go on. Its pretty obvious. What I'm concerned about is support for the lower control arm and/or subframe rails when the appropriate bolts are removed. The instructions are in japanese and there are no instructions on their english web site. I've searched for installs for these here on evom and have come up empty. Has anyone actually installed these? If so, did you have to support anything so that the bolts can be removed and nothing is damaged? Any suprises during the install? Thanks.
I didn't have to support anything at all. It's much easier if you have a lift.
http://www.nismogtr34.com/Pictures/B...h/IMG_0025.JPG
http://www.nismogtr34.com/Pictures/B...h/IMG_0026.JPG
http://www.nismogtr34.com/Pictures/B...h/IMG_0027.JPG
http://www.nismogtr34.com/Pictures/B...h/IMG_0028.JPG
http://www.nismogtr34.com/Pictures/B...h/IMG_0029.JPG
The bolt that comes out is almost pretty long. This next pic is of refference:
http://www.nismogtr34.com/Pictures/B...h/IMG_0030.JPG
Originally Posted by ExViTermini
I assume the idea behind these supports is for strength...but is there really that much flex right there?
Originally Posted by EvilBlueEvo8
well it is a weak point in the chassis and this makes reinforcement. you will get the most flex in that area with quick accel/decel/turns from autox. you other option is to get a 6 point underbar which will eliminate the need for these. problem is, if you need spacers for the regular underbars/four point bars to clear a downpipe, then you can't use a six point underbar cause you can't space the back two points. so your next option is to get a four point bar that can be spaced and then add these.
EVOlutionary
Originally Posted by EVOlutionary
Just a quick note to clarify what you wrote. In SCCA Solo II autocross, any triangulated or squared off subframe brace seems to be illegal in any class the EVO can compete in, including StreetMod. This includes both the RMR and Cusco lower 5 point bars. I learned the hard way.
EVOlutionary
EVOlutionary
If I did not participate in Solo2 racing, I would def. have some of these parts on my car! They look NICE.
EVOlutionary
