what are the cons of running spacers
Old Jun 15, 2006 | 04:06 PM
evo8silver's Avatar
Whats are the cons of running spacers on a road race and daily driven car? Please only post if you know for sure. Thanks Cus im thinking of running either 4 or 5mm spacers on my car. oh in front only
Old Jun 17, 2006 | 09:15 AM
evo_dadi's Avatar
which spacer do you have?the spacer with the stud together or just a spacer?with the stud/spacer combo youll be fine and just tq down the lugs well.as for the spacer you might wanna get longer studs for it so the lugs can be used properly and not halfway in.
Old Jun 17, 2006 | 09:16 AM
evo_dadi's Avatar
oh and no cons that i can think off since i just usually use a spacer when im autoxing.
Old Jun 17, 2006 | 09:21 AM
shiftdsm E's Avatar
sometimes the cheaper spacers arent properly aligned cause they are generic and they might cause you to get vibrations at speed, kinda like an unbalanced tire.
Old Jun 17, 2006 | 02:40 PM
kekek's Avatar
There aren't really any cons, although you should try and get your wheels in the proper fitment from the get-go. I use a front spacer on my race tires so that I can easily rotate tires/wheels. You won't get into the adaptors (studs built into new spacers) until you reach about 15mm thickess.
One big thing to be aware of is how many threads are remaining on the stud with the new wheels/spacer. You want at least 1 diameter to 1.5 diameter. Meaning you should have 12 to 18mm of thread engagement. Which is 8-12 turns minimum.
fluxcapacitor
Outlander Sport
34
Dec 24, 2016 10:04 AM
stunt2
Sep 17, 2014 06:56 AM
polish_pounder
Feb 7, 2014 09:51 AM
Evolution8.5
Mar 22, 2013 04:03 PM
eusgen
Jan 19, 2013 09:05 AM
