A Newbie Spring Question
HI,
Was just wondering in plain english. Does a stiffer spring basically mean that you will have less bounce on your car. So when you go over bumps it shouldnt compress as much right. And is this what makes the ride on stiffer springs harsher. Thanks for answer guys.
Start here:
https://www.evolutionm.net/forums/sh...d.php?t=205273
Suspension systems are not quite that cut and dry....everything affects each other....often times in ways you don't expect.
- Andrew
- Andrew
