proper way of lowering car?
Old Jul 17, 2006 | 10:58 PM
evo_rc's Avatar
I recently lowered my car with jic coilovers. I want to make sure i lowered it right. The front is a lil bit lower compare to the back juso it gives it a slight rack stance,but the gap is eliminated equally on all sides from the top of the tire. I was told by a friend who road race a lot to keep it like that for many reasons. Is this the proper way? or should the car be all even from ground.........
Old Jul 17, 2006 | 11:05 PM
z97219's Avatar
Is ok. If you want to be perfect then you have to find out your cars weight ratio on each corner.
Old Jul 17, 2006 | 11:11 PM
evo_rc's Avatar
dont want to get to that extent but I just want to make sure it is right before i get it align so i can just leave it alone...
Old Jul 17, 2006 | 11:22 PM
z97219's Avatar
For street use its ok. Adjust for rub, then align.
Old Jul 19, 2006 | 03:18 AM
trinydex's Avatar
if it's just for show... then just get it aligned otherwise read all the scc issues on suspension.
Old Jul 19, 2006 | 03:21 PM
EVOlutionary's Avatar
Most of the EVO race cars around here set pretty level (side skirts parallel with ground) or have the rear just a little bit lower than the front. For example, on my car the rear tire tucks up into the wheel well just a bit, but there is probably a 1-1.5" gap from the front tire to the front wheel well.
If you are going for looks just slam it as low as you can without rubbing.
EVOlutionary
Faust
76
Nov 6, 2018 06:47 PM
EvoIXPilot
Mar 17, 2013 09:47 PM
sanjaya1
10
Apr 13, 2010 10:54 PM
IVERSON3270
Sep 23, 2007 01:07 PM
joeymia
Southeast Region
Aug 24, 2005 04:28 PM
