BRAKE PROBLEM, is this normal?
Old Jul 19, 2006 | 01:11 PM
evoamac's Avatar
Unhappy BRAKE PROBLEM, is this normal?
Hi, i'm pretty new here, but i've searched and couldn't find a answer, anyways
My rear passenger rear brake is making a Grinding noise (NOT a high pitch sound)when i'm NOT pressing the brake pedal, especially when i'm turning or driving very slow ( < 20mph ). And if I press the brake pedal, the noise will be gone.
so, any thoughts?
Old Jul 19, 2006 | 01:14 PM
idriveanevo's Avatar
maybe a loose pad. mine was doing that i just replaced all the pads with ebc red stuff pads and it stopped but now they squeek when i hit the brakes, im confused
Old Jul 19, 2006 | 01:16 PM
TxEvo8's Avatar
It is probably the wear indicator, have you pulled the pads? It is extremely easy and the is a thread in the Installaions/How to forum to walk you through the process.
If you do need new pads (my pass. rear was the first to go), then I suggest some reasearch here to find suitable replacements. You can find real good pads for less than $200...
Old Jul 19, 2006 | 01:19 PM
TxEvo8's Avatar
Did you retain the stock shims?
Did you use copper anti-sieze on the backs of the pads? Lack of either of these will cause brake squeel..
evoamac's Avatar
ya, it was pass rear, forgot the type the "rear", anyways, thanks a lot, i'm going to my garage to check out my pads now, and also, since i have to order pads (if that's the problem), will it be ok if i keep driving for a coupld of days until the pads arrives, or will that damage my rotor. cus my beater Altima just decided to quit on me, have to use the evo to work. suks.
Old Jul 19, 2006 | 01:26 PM
Angry
yup, did everything right, at least as right as the post on how to do it on here. used shims, and anti seize. i just cant figure out why its still squeeling
Old Jul 19, 2006 | 01:35 PM
TxEvo8's Avatar
hmm, the red stuff is a street pad, correct? Did you bed them properly after installation?
Old Jul 19, 2006 | 01:39 PM
well.... i took it easy for a wile, maybe thats not proper.... whats the proper way to bedd them in? or is it to late?
Old Jul 19, 2006 | 01:49 PM
TxEvo8's Avatar
There is a thread on this somewhere, I suggest you search for it, but just make several 80-5 mph stops (8-10), then let the brakes cool by driving around for a few minutes.
Old Jul 19, 2006 | 01:53 PM
whitey4d's Avatar
I had EBC greens on my evo for about 1k then threw them away cause they sqeeled bad and I faded them several times. I replaced them with the ferodo ds2500. all I can say is what a difference. them stop alot better and barely ever make any noise. I bet its the compound that EBC uses that causes the squeel. especially since the reds are a "hotter" pad then the greens are.
Old Jul 19, 2006 | 01:59 PM
992gnt's Avatar
It's not the pads, the dust shield is bent a bit and it is rubbing on the back side of the rotor. Give the top of the shield a push through the wheel and your noise will be gone.
Old Jul 19, 2006 | 03:15 PM
EVOlutionary's Avatar
You can try the dust shield thing as mentioned above, but mine did the exact same thing and it was my pads. Stock pads went first in the rear. Don't waste your money on the Brembo pads from Mitsu, go with Ferodo, Porterfield, or ProjectMu. About 1/2 the price.
EVOlutionary
Old Jul 19, 2006 | 08:56 PM
evoamac's Avatar
ya, it was the pads, thanks guys. I just took off my pads and man, it was thin, (about 1 mm left), but i had to put them back on, cuz gotta order some pads and still need to dirve the car. anyways, thanks a lot EVO PEOPLE
Old Jan 11, 2007 | 07:18 PM
evo-mutsumiko's Avatar
thats just the way they are....it will go away with some time. then it will come back and then go away
i have the same pads. they suck i know
kyoo
29
Sep 28, 2016 06:23 AM
Inprogress
Mar 19, 2014 06:41 AM
guitardave24
Jun 27, 2010 10:53 AM
Jp7
Aug 17, 2009 07:51 AM
satanracing
Sep 13, 2004 06:17 PM
