HELP!! Brake Shim Question
Got a quick question.
Im replacing rear pads and turned rotors with halk hps.
The question is do you use the stock shims for the pads????
any input would be great.
HPS come with shims glued on the back so you should just need to use the metal shims. You should save the shims off the back of the OEM pads for later though in case you get something like Ferodos that don't have them.
Originally Posted by evo1337
wait there are two
1 has like little feet that wrap around the top of the pad
the other is glues to the pad
do i reuse the one with the feet?
ok got it done now the question is after freshly turned roters and new halk hps do the brakes feel spongy until they break in? I noticed that they seemed not to grab like normal but got somewhat better by the time i got back?
so is this normal?
so is this normal?
They shouldn't feel "spongy" but yeah until you bed them in they won't brake as well as they will after they are bedded in of course. Follow the mfgr's bedding-in procedure.
ok got it done now the question is after freshly turned roters...
so is this normal?
so is this normal?
Don't bleed the brakes either
Why did they sand them down through the wheels holes.... with a sander??? What do you mean the rear had lip problems? As for them looking bad, the rotors should go back to how they were after a little driving so no need to turn them for future reference
Originally Posted by QwikSRT4
I put my HPS's on without the non-metal shims and they squealed like a mother*****.
Put the non-metal shims on and they have shutup. Weird, eh?
Mine did the smething. But the brake noise went away after a week or so. Still get a little noise every once in while
