Hubcentric Ring
Hubcentric Ring
Okay I searched with the exact thread title I am posting. Because those words should produce my answer in my opinion. I think will help feature searchers with questions.
I am looking into purchasing 5zigen wheels. They say you need a hubcentric ring. Where does this ring sit? And what exactly does it do?
I was told briefly it centers the wheel on the hub. But where does it sit I can't exactly envision it. Any pictures would be appreciated.
Thank you.
Thank you.
its a metal ring designed specifically to the wheel your buying that centers it up against the hub, just a simple and effective way of making sure your wheels are center. and it really helps if people dont know how to properly torque down a wheel. ( torque in criss cross pattern) to install just simply plop the ring on the hub and install the wheel. Goodluck and post pics of the wheels!!
My big bro has them on his NSX with volks. I was under the impression that the hole in the center of the rim is bigger than the hub. So they have rings with different thicknesses for proper fitment. There should be a size guide. The one bad thing is that once its on you have to break it to put on a spare. Correct me if im wrong
The hub centric ring helps keep the wheel centered on the hub while you bolt it down to the car. If it wasn't there the wheel would sag and be bolted down crooked. Basically changes the center bore of the wheel, smaller not larger.
Why not make every wheel hub centric? If they did your wheels would cost thousands each because they would have to make a mold for every single application. Instead, they make lets say 50 molds/applications. Those 50 applications can then work on hundreds of different vehicles by using a different centering ring. The ring has to be tailored to the wheel and vehicle its designed for. Can't always take the rings from one wheel and have them work in another. The pic below is of a BBS centering ring.
Originally Posted by hopper
How much do you torque your lugs at? ive NEVER had a problem like that do yourself a favor and buy a torque wrench
Originally Posted by SpinOne05
I just bought 5zigen wheels and got hub rings for 18 bucks from discount tire direct. Do a search on Ebay to get the # and then call and order them.
i'm running them.
I'm glad that Neal posted on here as well as other informative people. This thread will be great for other people like myself and easy to search for
thanks to everyone
thanks to everyone
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
TommiM
May 27, 2010 09:13 PM
GoEVOGo
Jul 3, 2008 06:03 PM
badhabit90
56
Apr 5, 2008 02:54 PM
