smaller sway bar available for the front?
Old May 3, 2003 | 07:16 PM
Big Sky's Avatar
Curious if there is a smaller front sway bar available for the front? I know many like to increase the rear sway bar to dial out understeer, but I've found that going smaller in the front helps preserve/enhance the independence of the suspension- especially nice if one is running gravel much. You still are dialing out understeer.
Any chance the "normal" Lancer sway bar would work up front (don't what the diameter is)?
Something around 21mm (rear being 22mm) would probably work pretty well.
Thanks in advance.
Big Sky
Old May 4, 2003 | 03:32 PM
JNasty4G63's Avatar
I just happened to be browsing over at Vivid Racing's site. They have just what you're looking for. Here you go.
http://www.vividracing.com/evo/prod_sway.php
Old May 4, 2003 | 04:26 PM
Big Sky's Avatar
Thanks- that is exactly what I was thinking! Didn't know Dan was doing EVO parts.
Does anybody know if the front (rear for that matter) sway bars are interchangable between different evo versions? If they did it would be curious to see what other sway diameters were (are) availalble.
Thanks.
Big Sky
