Front wheel gap...?
The only thing that is bugging me about this car right now is that the front wheel gap is twice as large as the rear gap...
i'd love to be able to lower the car in the front by 1-2" but not affect the handling characteristics of the car, and also not have to worry about my tires rubbing... i do plan to upgrade to a lighter wheel, but stay with the 17" size...
what are my options as far as lowering this thing but maintaining the same manor it has now...?
I was actually pondering the same thing.. I kept thinking that the spring spacers were still in there because of the height.. The only system I've seen so far that I would consider is the TIEN coilovers.. but I would hate to sacrifice the current ride and make it firmer than it already is.. I like the feel of the car, just hate the gap.. On the other hand, if my car was any lower, I'd have way too much trouble with the Long Island Expressway, Speedbumps, and curbs..
The problem is the front wheel well is cut higher than the rear. It would look level and decent if the were cut the same. But, I assume they cut it higher in front because of front end dip, not sure though. maybe if you gonna rally the car and jump it it gives more rooom to play when the front end comes back down from jumping the car.
Guest
Posts: n/a
I dont know what you mean by "right". The suspension height front and rear is matched to the damper travel and hydraulic setup as well as the anti roll bar settings. If you lower the car in the front with springs for example, you will end up with less good a suspension setup.
Guest
Posts: n/a
Originally posted by hear no evo
i was thinking of lowering just the front to make it some what match the rear. is that not such a good idea?
So all cars that are lowered ride like crap and handle for ****? Well damn. Guess I'm not gonna lower it. I would rather have it right than it look good.
a lower car does not always mean a worse ride...
i think i may look into the Tein system... cause that wheel gap bugs the **** outta me, and i havew no plans on rally racing this car...
Guest
Posts: n/a
baegull
10
Aug 2, 2015 08:30 PM
09EsSport
Jun 4, 2013 09:50 AM
TeegsMR
May 18, 2010 05:57 AM
03SilverEvo87
19
Mar 5, 2007 04:59 PM
