Hawk HPS pads problem?
Old Sep 8, 2006 | 08:03 AM
xmaciek82x's Avatar
Originally Posted by EVOBrakes
better?
No squeeks this morning The real test is drive from work, but I think that fixed it. (Pretty funny how my original post evolved into a different problem that I had).
Old Sep 8, 2006 | 08:04 AM
xmaciek82x's Avatar
Originally Posted by rice_rocket88
The clicks drive me insane though...
What clicks?
Old Sep 8, 2006 | 08:30 AM
EVOBrakes's Avatar
The rear pads shift around in the caliper a bit - more audible on some than others.
My subaru 4 pots do the same - ah well...
Improper bedding/break in is likely the biggest cause of poor performance in brakes -
-remember who SUPPORTED THE PRODUCT next time you need brakes :wink:
(If the squealing returns I would try some CRC brake disc quiet (red can at NAPA)
Old Sep 8, 2006 | 08:34 AM
mitsuorder's Avatar
Yeah I believe all four of my pads click now, not just the rears. It's as if the pads shift when you take off from a stop or go straight after going in reverse.
Old Sep 8, 2006 | 08:39 AM
EVOBrakes's Avatar
It's not as if - it's what is happening. Many fixed type calipers do this.
Typical floating calipers are inherently designed differently and don't do this as the pads ride inside a bit of stamped spring steel.
It's a bit of sloppy stamping by backing plate company who supplies most of the pad manufacturers. It is better than if the pads were tight in there as you'd have pad drag which is a big problem in a hurry.
Old Sep 8, 2006 | 08:40 AM
xmaciek82x's Avatar
Yea, I had that when I put my HPS rear on. Couple days later I switched to OEM ones for the rear and HPS in front. They were very loud over pot holes and uneven roads.
Old Sep 8, 2006 | 08:59 AM
mitsuorder's Avatar
3 of my rotors are showing signs of odd wear patterns. Some are only showing wear marks coming from the outside edges of the pad and one is showing more wear coming from the inside of the pad. I was curious to know if the shifting around of the pads coudl be attirbuting to this.
AllDayAnthony
Mar 30, 2015 01:13 PM
2slow4now
Jun 6, 2014 03:00 AM
Icegod87
Apr 16, 2014 10:28 AM
Phantom X Evo
10
Aug 9, 2011 12:03 PM
riksride
Jun 10, 2009 05:20 AM
