New STANCE coilover goodies!!
Old Sep 8, 2006 | 08:19 AM
EvoPooPoo's Avatar
Full front and rear 3 way
These should kick ***.
Applications are to be announced.
Old Sep 8, 2006 | 08:21 AM
x838nwy's Avatar
dyno chart? for coilovers?
anyway, are these (shocks in the pics above) for the evo? don't look it to me. mounting look odd..
Old Sep 8, 2006 | 08:24 AM
evo 8 ya's Avatar
so what kinda power are you looking to get out of them?
Old Sep 8, 2006 | 08:35 AM
EvoPooPoo's Avatar
it's called shock dyno. The coilovers pictured are for different application.
PVP charts shows how well the coilovers react to compression and dampening.
no comment to your "how many hp out of your coilovers..." statement. your ignorance speaks for itself.
Old Sep 8, 2006 | 08:54 AM
eddie's Avatar
I'm pretty sure it was sarcasm. Lighten up...
Old Sep 9, 2006 | 12:42 AM
WWEVOIX's Avatar
sorry dunno what shock dyno is any indepth info? i have a set of stance right now and they kick @$$... love them... but if they are coming out with something newer and better... i guess mine are up for sale.. hehe
+1 nice find
Old Sep 9, 2006 | 01:03 AM
x838nwy's Avatar
the 'dyno' as referred to here I think consists of normally two plots.
one looks like a series of ellipses and is a plot of force (kgf, N or lbf) against displacement at constant speed. the other is the usual force against telescoping speed (mm/sec or in/sec etc.) and look like two slanted lines going from the origin. You can get them done on damper testing machines and so forth and they normally tell you the characteristics of the damper in question. Often seceral lines are on the same plot for differnt valve postions (for adjustable shocks) so you see graphically the range and resolution of the adjustment. Very useful if you have like 3-way adjustables or something since it's kindda hard to get them tuned by feel alone. Also useful for comparing dampers. If one set of curves work good then if you start with another brand you try to start with the closest curves then play around from there.
Touge Factory
27
Nov 24, 2008 04:19 PM
Touge Factory
Aug 18, 2008 03:26 PM
EvoPooPoo
47
Aug 11, 2008 08:31 AM
EvoPooPoo
Sep 9, 2007 05:49 AM
EvoPooPoo
Jan 28, 2007 09:16 PM
