Swift Spring Alignment Specs.
Old Sep 13, 2006 | 05:46 PM
andifidie's Avatar
Hey guys!
Forgive me if this has been beaten to death. I used the search button and couldn't find what I was looking for, so im hoping one of you suspension gurus can help me out.
I have an EVO IX gsr, right now lowered on swifts until I get some coilovers. Its been about 2 weeks since installation and I feel its time for a good alignment. Do any of you know a good place in socal (irvine, laguna beach, orange county area) where I could get a good alignment for street and occasional track use. Exact alignment specs would be great being I know nothing about aignment. Thanks a lot guys.
Old Sep 22, 2006 | 08:24 PM
Noob4life's Avatar
A street alignment can be done at almost anywhere, as any shop should be able to zero out your toe, the most important thing.
IMO, light track use means lapping days and random autocrosses in which you're just looking to have fun and aren't looking to be super competitive. In which case, an aggressive alignment is not necessary at all, and a regular street alignment would do just fine. Any benefit you might see from running a bit of toe in or out would be greatly offset by the increased tire wear, not worth it for a DD IMO, especially not with a good set of tires costing what they do.
Old Nov 8, 2006 | 04:34 AM
ecko_3420's Avatar
so im also planning to drop my evo 8 gsr with swift springs...heard good stuff about these springs..my question is do i need camber kits??why wait 2 weeks for the alignment??
Old Nov 8, 2006 | 12:34 PM
MRgraphite's Avatar
because the springs will settle during initial use. So if the car is aligned, then the springs lower some more, this will change everything you just paid for. Depending on how much you drive, how rough the roads will ultimately determine how long it takes for the springs to settle. I think 2 weeks given that the car is a daily driver is a generous estimate to make sure the springs are where they are going to stay and then align the car.
Old Nov 8, 2006 | 12:35 PM
andifidie's Avatar
^ what he said...
Old Nov 8, 2006 | 12:40 PM
Smike's Avatar
Originally Posted by andifidie
Hey guys!
Correct 0 toe.
Without camber plates your max camber you can reach will be around -1.5ish deg. for the front and -1 for rear.
For mostly street use - thats fine. I would go -1.5, -1 with zero toe and max pos.(sorry thinking of camber when writing that...) caster (from my specs I want to say +3'55).
Old Nov 8, 2006 | 12:57 PM
andifidie's Avatar
Originally Posted by SmikeEvo
Correct 0 toe.
For mostly street use - thats fine. I would go -1.5, -1 with zero toe and max neg. caster (from my specs I want to say 3'55).
those are my specs ut i have a little toe for highspeed stability
Old Nov 27, 2006 | 01:53 PM
NoTec's Avatar
Bringing this back from the past. I went in to the dealer today to have my alignment done after swift spring install (06 Gsr). They have been on the car a month now but the car isnt daily driven so I'm assuming they have settled in by now. Anyway, I was told by the dealer that the rears can be re-aligned to stock spec but the fronts can not be brought back to stock unless i use camber bolts (made by Ingalls) or a set of camber plates. I just want the suspension re-aligned to stock and nothing else. I dont track the car nor do I ever plan on tracking the car in the near future. Can someone chime in and let me know whats best for my situation. Thanks.
Old Nov 27, 2006 | 02:17 PM
NoTec's Avatar
Bump again for the suspension guys who may have an answer for the question above.
Old Dec 3, 2006 | 06:30 AM
Bosshog's Avatar
you mean the fronts will have less chamber (than bone stock) with the swifts even after an alignment unless you get chamber plates?
Old Dec 3, 2006 | 07:27 AM
91TB78's Avatar
NoTec,
The dealer isn't making sense. As you lower a car you should be able to gain more negative camber then stock.
My suggestion is take it to a good reputable alignment shop or a race shop to have it done right.
Old Dec 3, 2006 | 09:24 AM
Evo05lution's Avatar
yea your first mistake was taking it to a delaership...they suck
Old Dec 3, 2006 | 11:20 AM
Jim_Patterson's Avatar
You dont need camber bolts. You could get ~-1.8 camber in front by turning the eggcentric bolt in the front struts. Mine was aligned to -1.5 in front and -1.0 in rear if i remember correctly.
Old Jan 22, 2007 | 09:37 AM
milo's Avatar
I'm in the process of installing my Swift spring on my Evo 9 MR. Can I align my Evo back to factory spec, without the camber plate? Also, do I need to purchase set of bumpstop(Whiteline)? Thanks
Old Feb 2, 2007 | 09:47 PM
Jordanz3's Avatar
bump for answer
