EVO VIII Factory Alignment Specs?
Old Sep 13, 2006 | 09:02 PM
EiEVO's Avatar
Question EVO VIII Factory Alignment Specs?
Does anyone know the factory Camber and Toe specs?
Thanks.
Old Sep 15, 2006 | 09:47 AM
Steve_P's Avatar
if you search this board you will find it. I just did this a few weeks ago and it's here several times. Check the end all thread at the top first.
Old Sep 15, 2006 | 11:34 AM
DaWorstPlaya's Avatar
Factory has a spec range:
Front camber: eccetric bolt turned in or out, 0.75-1.8 deg negative camber
Front toe: 0
Rear camber: 1-1.3 negative camber (adjustable)
Rear toe: 0 or slight toe in ...
LVSBB6
May 28, 2013 07:32 PM
1800bigk
Sep 18, 2011 09:53 PM
rvcaman
Jan 24, 2010 09:19 AM
heSOshAdy
20
Jul 27, 2008 03:31 PM
rpm-evo
Jun 4, 2004 01:21 PM
