Alignment/Balancing
Old May 7, 2003 | 01:02 AM
bad karma's Avatar
Alignment/Balancing
yea, so as stated in the subject, is going to get your car balanced the same as getting your car aligned? Can the mitsubishi dealership do it for me? If not then where can i go? how much does it cost to get done and how long would it take to get done? thanks for the info if possible...
Old May 7, 2003 | 01:12 AM
iodine23's Avatar
You mean get the tires balanced? I had WalMart do my last tire mount/balance when I needed to replace some old worn tires. Their prices were very reasonable, somthing like $22 to mount and balance two tires and dispose of the old rubber. I don't think it takes too long to do, normally you wait more for the cars in front of you than anything else.
Old May 7, 2003 | 01:40 AM
theheff's Avatar
Balancing refers to making the wheels spin w/o vibration/imbalance. Alignment refers to adjusting the way the wheels are oriented relative to the chassis/suspension. They are two completely different things. Either procedure is usually a walk in and both can usually be done at a reputable wheel-tire store (i.e. America's Tire Co., etc.) Balancing is probably ~$30 and alignment is probably ~$50-60. Hope this helps~
Heff
Old May 7, 2003 | 08:40 AM
XeroDgrees's Avatar
Alignment refers to setting the toe, camber/caster etc... Pep boys does 4 wheel alignments for $59.99 depending on the area.
Balance just means they balance your wheels by putting weights on the wheels to counter balance the offset.
Old May 8, 2003 | 04:21 PM
Max Rebo's Avatar
Ideally, try to find a place that has one of those newer Hunter wheel balancing machines. You can do what's called "road force matching," which places a load on a wheel/tire combo to simulate driving on a road, and then they look for balance inconsistencies.
Old May 8, 2003 | 04:28 PM
initialDRacer's Avatar
I have a car that is lowered and I hear this weird vibrating sound when I reach 50+ mph. Does my car need balancing or what? I can't seem to find where this buzzing sound is coming from so my first guess is my tires. I have stock tires/wheels btw. What you guys think?
Old May 8, 2003 | 04:35 PM
BlkLancer's Avatar
initialDRacer how low did you go and did you have it balenced when you had it lowerd cause your really supossed to have it balenced and what not anytime you drop your car. they say RRM progress springs you don't need to but you should anyway. so if you didn't i would go have it rotated balenced and aligned and see if that solves the prob.
Old May 8, 2003 | 04:40 PM
BlkLancer: I had it aligned after my car was lowered. But the tires I have not yet balanced...
