stock 06 MR wheels offset
does anyone know what it is? i did a search and 1039 pages came up. i might have missed the thread when i was skimming through. i want to know in reality if you can run a 18x8.5 with a 245 tire and not rub.(lowerd)
thanks in advance.
thanks in advance.
Knowing the stock offset is not relevant to figuring out if a completely different size rim/tire combo will work with a different suspension setup than stock. You need to specify the exact rim size, tire size, and suspension changes for us to figure it out, but a 245 is pretty small, so you shouldn't have much problem.
I can say it does not make much sense to spend gobs of money on 18" rims that only use tires that are 10mm wider than stock. If you're just trying to go for looks with 18" bling rims and some lowering springs, then at least get something that will improve your handling and increase the contact patch significantly. JMO...
kkmoslehpour
Evo X How Tos / Installations
Apr 24, 2011 01:44 PM
