tire pressure??
tire pressure??
what tire pressure do u guys recommened for the front/back on my stock 06 MR? would filling what it recommends on the door sil really be the best ? or do you guys know of a better pressure measurment that i dont know about?
My 06 MR didn't have any good info on tire pressure on the door but the user manual did. Check your manual and read up on it. I decided to run what it said would be the higher air pressure for faster driving. 38 cold psi in the front and 35 cold psi in the rear. I also decided to switch to that from the usual 33 front 30 rear or so because I noticed that my outside tire tread was wearing a little quicker than the middle tire tread.
For street 35-38psi front and 32-36 rear is a good balance between handling and comfort. For aggressive driving 39-41psi front and rear is good, depending on alignment and the handling characteristics you want.
Whats max pressure on the tires you're running? At our shop we try to keep it 7pts. away from max. this way you can insure room for expansion and deflation. Having more air will help in handling, grip and will also give benifits to tread wear and rim protection.
