Another Brake Pad advice question
Old Oct 9, 2006 | 12:27 PM
Aby@MIL.SPEC's Avatar
I am looking for a pad that has similar cold braking / stopping feel as the oem's, but is better than the oem pad for spirited driving.
here is my situation/story
I live near a hill, ~ 200 yards away from my driveway & I know by wife will complain about a hard brake pedal, poor braking ability, especially when the street "T"'s into a busy road & 2 kids in the car!
I have driven a car with ferodo's & hawk hps, the ferodo's were worse with the heavy pedal effort, while cold, down the same road & I know i dont want either of those 2 pads.
Thanks for any constructive advice?
Old Oct 9, 2006 | 12:45 PM
Smike's Avatar
Did that car you test have steel lines? A soft brake pedal on an Evo isnt normal (air in line...?). I am running track pads in my Evo now and DOT4 fluid, but stock lines. And the pedal feel is no different than stock.
Well she doesnt have to drive the Evo. Next question.
Its a trade off, you either want comfort or ability. So going to anything that is a step up from OEM will have less comfort. Be that noise, feel, wear...
As far as other pads go: I liked my Satisfied GranSport 6s, worked fine for daily spirted driving.
From: http://www.satisfiedbrakes.com/motorsports/index.html#
"...friction coefficient of 0.38 – 0.42 in a 100 – 700°F operating range."
Pricewise: ~113 front, ~74 rear.
Old Oct 16, 2006 | 11:22 AM
some more input / insight would be appreciated
Old Oct 16, 2006 | 11:32 AM
naucrx's Avatar
I've used OEM, EBC green, Project Mu B-force, Hawk HPS and Ferodo DS2500.
I like the Ferodos the best by far. I can't say there's much difference in the pedal feel between those or any other pad I've had on the car. But I know when I press the pedal that my car is going to stop, even after a lot of spirited driving. I'm also running the SS brake lines and Dot4 fluid. I'm surprised you've ruled those pads out.
Old Oct 16, 2006 | 01:13 PM
EVOBrakes's Avatar
Comparing 2500's to HPS isn't right - they are more like HP+
HPS should work fine at cold temps - they are STREET pads.
But seriously - asking for pads that work better both cold and hot than OEM is like asking for a turbo that makes more HP up top AND spools quicker down low - it doesn't really exist. There are always tradeoffs - simple as that.
Old Oct 16, 2006 | 01:25 PM
batmoEVO's Avatar
Don't know what the complaint is about the Ferodos. I have had 2500's, stock rotors, RBF 600, and tracked the crud out of those pads. No fade ever, same friction coef cold and hot. I think they are amazing pads that feel slightly better than stock on the street, but can take the heat of the track over and over and over.
BTW - I'm talking rotor temps of 1000ºF+.
Old Oct 17, 2006 | 08:43 AM
I never asked for other pads "that work better both cold & hot".
I understand that i will most likely be giving up some cold bite & feel, that is why ask for something similar.
Thanks for the input
Old Oct 17, 2006 | 08:58 AM
mitsuorder's Avatar
The Hawk HPS pads are ok if you're broke. Unless you're down to the stock pad backing plate the HPS will most likely be dissapointing. The DS2500's are extraordinary.
Old Oct 17, 2006 | 09:05 AM
EVOBrakes's Avatar
HP+ or DS2500's are what you want then.
Old Oct 17, 2006 | 09:51 AM
homiusang's Avatar
I agree. The Hawk HPS is the worst after market pad I have ever used. Though I didn't use them on an evo, but on my STi. They also have the worst "feel" ever.
Old Oct 18, 2006 | 07:04 AM
jbrown's Avatar
+1 for the 2500's and +1 for Ken (EVOBrakes)
Old Oct 18, 2006 | 09:17 AM
everyone loves the ferodo 2500's
maybe the ferodo's that i drove on were not the 2500's?
I had ferodo's on another car a few decades ago & liked them, however that was a completely different car, 61 mini w/cooper s brakes
