Need Help Replacing Rotors
Old Dec 10, 2006 | 06:06 PM
one_fas_evo's Avatar
time to change my rotors. just bought some stock rotors. can some please forward me a DIY write up, if one exist. thansk in advance
Old Dec 10, 2006 | 06:11 PM
cfdfireman1's Avatar
1.Raise car
2.Take off wheels.
3.Remove calipers
4.Remove rotors
Reverse order for reassembly.
Old Dec 10, 2006 | 06:12 PM
ak47po's Avatar
If you have to ask,don't attempt.Pay a shop.
Old Dec 10, 2006 | 06:15 PM
D-machine's Avatar
I just changed mine the other day. It was easy just remember to get 2 8mm 1.25 bolts so you can pop off the rotor easier. If you are also doin the pads get somthing sharp like a knife so you can pry off the metal backing plates start it with a knife then put a screw driver in and pry it the rest of the way. Plus no you don't have to bleed the system either just don't crack it open.
Old Dec 10, 2006 | 07:50 PM
i've changed rotor on honda's before but when i took a look at the evo rotors, it looked difficult. just needed advise, not negative input.
Old Dec 10, 2006 | 07:52 PM
2 bolts removed from the rear.
sofly1990
14
Jan 27, 2012 05:09 AM
nman77
15
Aug 5, 2010 11:26 AM
silentmunky
10
Mar 16, 2009 02:50 PM
little
Jan 10, 2006 09:50 AM
possman
Jul 9, 2004 08:31 AM
