Is there anything wrong with stock Strut bar?
like the tittle says, I ask because I see a lot of people seeling theirs because apparently they have replaced it with something else? (aftermarket I assume)
I doubt you will ever notice a difference with the aftermarket ones, mitsu did a dam good job making the stock one, only benefit of aftermarket would be one that has a brace like the carbing...
When I took the stock one off I noticed it is alot more pliable and bends much easier than aftermarket strut bars. I still think its strong enough to keep the car from flexing though but not sure if it would do as well as the aftermarket strut bar.
I can't imagine making it out of anything (even titanium) and getting a bar that is lighter than 2 lbs, so you're talking a weight loss of 5 lbs at most.
That being said, I have the mitsu aluminum one which is a couple of lbs lighter. Can't hurt.
d
d
good aftermarket ones might save weight, be a bit stiffer and add some bling but also seperates your evo from the rest. i plan to get a works one but first i want to get things that my evo doesn't have before i upgrade things it does have.
