hawk hps squeek????
Old Jan 2, 2007 | 07:29 PM
dave9172's Avatar
hawk hps squeek????
i put in new hawk hps pads about 300-400 miles ago. i know they are supposed to squeek for the break in period, but god how long does that last? they still squeek but not as bad as when i first put them in.
Old Jan 2, 2007 | 08:03 PM
thedarkside's Avatar
As long as you have them they will squeak. Welcome to performance pads.
Old Jan 2, 2007 | 08:05 PM
Cirrusly Evolvd's Avatar
Mine haven't squeaked since about a week after installing them...they only do so if I'm really mashing on the brakes a few times such as after 1/4 mile runs.
Old Jan 2, 2007 | 08:07 PM
bvdawg13's Avatar
mine have never squeaked
Old Jan 2, 2007 | 08:09 PM
littlemilla3's Avatar
I had them on my last car and they did not squeak at all. It's really important to bed them in properly right after you install them.
Old Jan 2, 2007 | 08:15 PM
xballsport's Avatar
Mine make noises to this day(had them for like 2.5k miles), almost all the time at very low speeds but not as horrible as day 1. I simply got used to it.
Old Jan 2, 2007 | 08:21 PM
The bedding process makes all the difference.
Old Jan 2, 2007 | 08:34 PM
boostless's Avatar
Its normal...porsche GT brakes squeak, race brakes squeak. The people that say they dont are just fortunate. Get used to it
Old Jan 2, 2007 | 08:37 PM
caLi4G63's Avatar
i got the hawk hps also and mines do squeak occasionally; like other members stated on this thread, get use to it.
Old Jan 2, 2007 | 08:44 PM
xmaciek82x's Avatar
x10000
Old Jan 2, 2007 | 08:46 PM
EJEvo's Avatar
Some people have no problems with them, others squeal like pigs and they hate them. They really shouldn't squeek since they are a street pad and not very aggressive within Hawk's product line. There seems to be no rhyme or reason to it. I'm sure break-in, rotor condition, install process, ambient temps, etc. all contribute in some way to it. I've had my HPS rears on (ran HP+ on the fronts during track season) for about 3K and they've only recently begun to squeal on occasion. Wear it as a badge of performance.
Jeff_Jeske's Avatar
I would never have a pad that squeeks installed for the street!!!
Old Jan 2, 2007 | 08:47 PM
theblue's Avatar
they're going to make noise, but they're nothing close to as bad as my hawk hp+ pads which scream.
pad should make noise because they're not up to temp yet, not because you're using them a lot (once up to temp they should quiet down a lot). Using anti-squeel stuff does help and the HPS really shouldn't be that bad....
if you're not driving your car hard enough to fade whatever you have then that's good advice... I like to street/autoX/track without switching pads and tires... the HP+ is the best I've found so far. I've grown to be used to the noise... makes me feel like I'm in a race car, probably because I am.
Old Jan 2, 2007 | 08:52 PM
mac_05evo's Avatar
I'm on my second set and neither set has squealed too terribly.. The first set I had did pretty badly when they were new, but I think that was because I didn't bed them in right.. The 2nd set I'm on now hasn't squeeked in a very long time, if ever (excluding initial bedding of brakes)
Old Jan 2, 2007 | 09:00 PM
EJEvo's Avatar
Try Performance Friction PFC-97s for true auditory assault. A buddy of mine runs them on his 325i, and when we go into Watkins Glen for lunch, every touch of the brake makes people in a 3 block radius stare at us. The odd thing is, he says they stop squealing a day or 2 after a track day.
