Question about Evo8 rotors???
Old Jan 4, 2007 | 11:41 PM
Adrian_3g's Avatar
My question is will the stock rotors fit a 03 eclipse? I want to get the stock rotors and swap them onto the 3g for the front and rear. Can anybody hook me up with measurments or proof that it will work?
Old Jan 5, 2007 | 12:20 AM
Adrian_3g's Avatar
Bump anyone know the answer to this?
Old Jan 5, 2007 | 12:29 AM
KartaRailed's Avatar
There are a few things to consider here.
Are you getting evo brake calipers too?
Is you car a 5x114.3 bolt pattern? I have no idea.
How big are the wheels, will evo brake calipers fit inside the wheels? 17 inchs are a must.
In a direct answer, no the evo brake rotors will most likely not fit without modifacations, and will definatly not fit with your stock calipers.
Old Jan 5, 2007 | 12:37 AM
Adrian_3g's Avatar
Well i wanted to get the complete brake system and swap it over to the 3g. I guess im going to have to find some other rotors.
Old Jan 5, 2007 | 01:04 AM
If your taking the entire brake system you will just need to see if the two bolts that hold the calipers on to the suspension on your car will fit evo calipers. I know for a fact that evo 8 and 9 brembo calipers bolt right up to 2g DSM's, so it might be worth lookin into for you. Im sure brembo makes a big brake kit for your car utilizing the same calipers as evos have.
Old Jan 5, 2007 | 03:41 PM
mrMTB's Avatar
Alternately, if the calipers do not mate up, search around to see if any place makes an adapter "torque member" to interface between the car and the caliper.
Foxman92
Jan 10, 2016 06:49 PM
4g63girl
Nov 4, 2013 01:24 PM
plip630
Jun 23, 2011 08:23 PM
LostSoul Evo
Apr 30, 2009 09:27 PM
Green_Bandit
Oct 5, 2005 11:59 AM
