Vendors: Need Buddy Club P1QF, 18x10
I found another website that listed them as also available in a +35 offset. I guess I should trust BuddyClub's website first, though.
Kekek - did you weigh those yourself? Everything I found said they were 23#. If you weighed them I will update my list . . .
https://www.evolutionm.net/forums/sh...ad.php?t=24232
The BC in 18x10+35 is 16.1#, the +12 version is about 16.3.
My WedsSport SA70 in 18x10 is 20.2# . . .
Right now I run a +32 offset rim in the front with a 10mm spacer - so an effective +22mm offset. I think I could fit another 10mm in there without much problem. . . but the back will take some creative work!
EVOlutionary
EVOlutionary
Yeah, I weighed the wheels myself. Those Weds are reltively light, not too pricey either. My 18x9.5's +35 I run a 10mm spacer (+25 effective). This gives me good breathing room on the shocks (Tein RA's). I would imagine the Ohlins have better clearance as I know the RA bodies are a little large. With no spacer rear I get rubbing on the trailing arm with a 285 V710, so there isn't any inboard room to work with. Although in SM you could run an alternate trailing arm$$$, I'm stuck in SP.
If you are rubbing on the rear trailing arm then a +12 offset will push the wheels out and solve your problem! Just need to either get a widebody or go crazy with a Sawzall and and slap on some plastic fender flares like alot of the Honda and VW guys run in the SP classes !!
I am going to contact a vendor about setting up a group buy on the Buddy Club QFs. There HAS to be 8 or 9 more people in the world who wants the lightest 18x10 possible. . .
EVOlutionary
supersnow
10
Mar 10, 2011 08:58 AM
cal1mr
13
Jan 3, 2008 01:31 PM
