Negatives of Megan Coilover?
Old Jan 11, 2007 | 01:05 PM
ez's Avatar
ez
I switched from JIC FLT-A2s to Megan Track series months ago for my track setup and am very happy with them...actually in preference over the JIC. I believe they rival the performance of units easily twice their price.
Yes...there is a list of good reasons to buy more expensive coilovers, which any pro race team could easily outline for you. But with the continued rapid advances and lower costs in material and manufacturing technologies coupled with immense retail competition, that list is growing shorter by the month.
Most coilovers are built with similar materials, basic design, and construction while they are varied in capacity, dimension and valving. The majority of what you pay for is the research and testing they have done combined with with the competition experience.
As more people begin to race budget setups, the level of knowledge (research) that can be applied to the budget hardware increases. This begins to slowly close the performance gap between low and high dollar hardware.
As for noises, as long as parts are not faulty and are properly torqued, there should be no "clunking". But what happens with coilovers is the collars work loose over time from vibration and allow either spring play or the body to move within the bottom mount. This causes a clunk when the suspension loads/unloads, and can also contribute to strange handling and bad alignment characteristics.
Although there is Locktite that is safe for Aluminum, I would not advise it on the treaded bodies. I and others have found that the collars will stay put if you have them tight enough.
Regards,
Ethan
Old Jan 11, 2007 | 02:52 PM
Noob4life's Avatar
Actually the price of materials has gone up quite a bit lately.
The real list of reasons why someone would purchase your typical $1k/corner setup over a $1000 complete set is very short, and not likely to change. Which is fine, because the $1000 complete setup is not meant to compete in any way with the $1k/corner setup (and anyone who tells you otherwise is trying to sell you something...).
Old Jan 11, 2007 | 03:18 PM
prostcj's Avatar
Originally Posted by lexat20
no, just the normal sounds that a car makes when going over bumps and such
What about the clicking noise that comes with low speed turns? I thought that was a normal sound of CO. It comes from the front and I was told it was from the spring moving around.
Old Jan 11, 2007 | 06:02 PM
Noob4life's Avatar
Clicking during turns is usually indicative of a busted cv joint. I don't see how it would be possible for a spring to produce a clicking noise under any circumstance.
Old Jan 11, 2007 | 06:56 PM
prostcj's Avatar
It's not the same noise.....I've had bad CV joints. The noice started immediately after installing the coilovers.
The noise has been the same for about eight months now. It's not a rotating noise, it's more of a binding noise.
Old Jan 11, 2007 | 09:43 PM
Jordanz3's Avatar
bump
Old Jan 12, 2007 | 07:21 AM
Jordanz3's Avatar
ttt
Old Jan 12, 2007 | 07:36 AM
Smike's Avatar
Pretty much summed up by everyone else here. I have nothing but +'s for my Megan Tracks.
Old Jan 12, 2007 | 02:47 PM
Noob4life's Avatar
Make sure that nothing is getting caught between the suspension linkages below during suspension travel, such as brake lines or brackets rubbing.
An easy way to do this is to take the spring off of the assembly and install it, with just the shock alone. With the car up in the air on jackstands, compress and extend the suspension manually while checking for anything that may bind or rub during this travel. Also have someone turn the wheel to some-what simulate a cornering situation.
Check the wheel wells for rubbing of the tires as well.
Old Jan 12, 2007 | 02:53 PM
rjdevo9_mr's Avatar
+1 Noob4life...you might want to check the wheel wells for rubbing, my friend had that same problem and he noticed his tires were rubbing at the top of the sidewall
Old Jan 12, 2007 | 02:59 PM
DaWorstPlaya's Avatar
+1 ... the magic is in the shocks. Everyone who buys these coilovers are going to say they are good, as no-one wants to think they wasted their money on something worthless. The problem is most of the reviews you get are from drivers who either don't track/auto-x their car or have very little experience with various products and performance driving in general. That is why I tend to take reviews from just anyone with a pinch of salt, actually more like a bag.
Old Jan 13, 2007 | 01:26 PM
Jordanz3's Avatar
ttt
Old Jan 13, 2007 | 05:53 PM
prostcj's Avatar
I've been told that the sound I've got is probably the spherical bearing. I'll have to look into it more.
Old Jan 13, 2007 | 06:12 PM
jaymzz's Avatar
Thanks everyone for the reviews. I have been looking at these coilovers myself.
Old Jan 13, 2007 | 06:16 PM
34Turbo's Avatar
Sti's seem to have a lot of clunking issues when it comes to suspensions. I think its normal.
