brake light...
brake light...
not sure if this is the right spot to post this, but here goes...... a couple times lately, usually when i'm driving kinda hard my brake light comes on, i only have about 23k miles on an 04 with a ssqv vta, act extreme clutch, and hks turbo timer type one (those are the only mods and i don't think they'd cause this)... i've kept up with every service and it happened when i launched last night, stayed on for about 5 minutes and turned off..... is this something i should get checked out, is this common, should i be worried???
you're talking about the ebrake light right?
did you happen to connect any wires from your turbo time to the wire on the ebrake? when i installed my tt it had a wire that went to the ebrake wire under the console so the car would shut down if it was running on the tt and someone dropped the ebrake handle to drive away.
could that have come loose?
