Tire Scapling...please Help
Subscribe
Jan 26, 2007 | 09:31 PM
My Yokohama Advan Neovas (180 wear rating) came with a warning sticker stating the tires should not be stored in temps lower than -14 F or else the rubber compound would be damaged. Driving on them in these single digit temps just kills them. The dealer warned me that the stock tires would likely chunk in temps lower than 40 F.
The stock tires are simply not safe for cold weather driving.
Reply 0
Jan 27, 2007 | 03:28 AM
yea that just looks like a camber and toe issue... not like the tire fell apart or anything...
Reply 0
Jan 27, 2007 | 07:50 AM
Quote: yea that just looks like a camber and toe issue... not like the tire fell apart or anything...
I guess its a combination of everything...heel and toe, really frigid NY weather the last few days, 14k on the tires, and possibly out of allignment. I just wanted to verify that I wasn't having something out of the ordinary happening to my tires.
Tires are really haggard now...gonna have to order some all seasons I think!
Any favorites?
Reply 0
Quote: My Yokohama Advan Neovas (180 wear rating) came with a warning sticker stating the tires should not be stored in temps lower than -14 F or else the rubber compound would be damaged. Driving on them in these single digit temps just kills them. The dealer warned me that the stock tires would likely chunk in temps lower than 40 F.
What winter tires are you running?
Where in upstate?
Reply 0
Jan 27, 2007 | 07:53 AM
I would be happy you got 14k miles out of them. I only got 12k out of my stock AO-46s. This is perfectly normal for those tires. I also run the RT-615s now. At least they are cheaper to replace.
Reply 0
Jan 27, 2007 | 07:58 AM
Quote: I would be happy you got 14k miles out of them. I only got 12k out of my stock AO-46s. This is perfectly normal for those tires. I also run the RT-615s now. At least they are cheaper to replace.
You run those Falken Azeni RT-615's in snow?
In PA you must get a good amount of snow like NY right?
Reply 0
Jan 27, 2007 | 09:38 AM
Don't bother trying RT-615s in the snow - bad idea. Getting all-seasons will suck for the handling of your Evo, so I would suggest only getting them on a spare set of rims. YOu need to keep a good set of tires for summer driving, otherwise the Evo really loses its edge.
Reply 0
Jan 27, 2007 | 10:00 AM
Quote: Don't bother trying RT-615s in the snow - bad idea. Getting all-seasons will suck for the handling of your Evo, so I would suggest only getting them on a spare set of rims. YOu need to keep a good set of tires for summer driving, otherwise the Evo really loses its edge.
Have any of you guys tried the Yoko ADVAN S.4.'s? At around $180 per wheel not too bad compared to stockers and at least they're all seasons.
Not really good for summer though are they?
Reply 0
Jan 27, 2007 | 10:11 AM
I wonder if you keep you evo in a garage @ +40 F and then take it out to drive would that happen? Tires would only get warmer right. I have had no problems lately in VA as my 18" summer tires sit on the floor and I wait for the stockers to wear out so I can replace them with some all seasons.
Reply 0
Jan 27, 2007 | 11:03 AM
Anyone know about those ADVANS?
Worth it or not?
Reply 0
Jan 27, 2007 | 01:30 PM
Reply 0
Jan 27, 2007 | 04:29 PM
Quote: ???
If no one answered your other thread asking for info on these S4 tires, why do you think you'll have any better luck going off-topic here?
Check here.
Reply 0
Jan 27, 2007 | 08:07 PM
Quote: If no one answered your other thread asking for info on these S4 tires, why do you think you'll have any better luck going off-topic here?
Check here.
IDK...was hoping someone might have tried these out.
Reply 0
Jan 27, 2007 | 08:10 PM
Never heard of them.
Reply 0
Jan 28, 2007 | 07:13 AM
Quote: Never heard of them.
I think they are a fairly new tire to Yoko. They are rated to last a bit longer than the Falkens, Kuhmos, and Toyo Proxes so I thought they might be worth the money; considering all factors involved having to replace tires.
Some have even recommended Bridgestone Potenzas at $135 per tire. I does seem though for a little more the Yokos S4's might be a good choice.
Reply 0
