how low is to low?
Old Feb 4, 2007 | 08:53 PM
  #31
xxtomxx's Avatar
mine is 3inches drop and it look nasty
Old Feb 4, 2007 | 09:57 PM
  #32
evo150's Avatar
if you are happy with the swift springs why not just upgrade your wheels and tires to 18's? you get to keep the springs you like and enhance the "look" of your car
Old Feb 4, 2007 | 10:29 PM
  #33
ultimatesteve's Avatar
Originally Posted by GTWORX.com
Satisfying to see someone speaking some sense.....
All alliteration aside, how low do you want it? Do you think you'll miss or even notice the difference in handling? I hate to say it, but just getting Tein S-techs will probably make you happy. It really doesn't sound like you care about handling. You'll blow your stock struts/shocks shortly, but hey, who cares right? At least it's low!
- Andrew
Sorry andrew but you are completely wrong in your post. Please take the time to read everything before commenting.
Originally Posted by ultimatesteve
Thanks warrtalon. If I install the balljoint extenders and have someone corner balance it could I at least get the front end down some or is it pointless to even try. I want it lower but Im not willing to give up handling, thats why I posted this. But I do want to get it as low as possible, so if I could get away with doing something like balljoint exenders that would allow another 1/2 inch I wouldnt have a problem with it.
Right there it says " I want it lower but Im not willing to give up handling, thats why I posted this." If it was absolute fact that you CANT go any lower then what the swift springs are already at, then I wouldnt bother going any lower. BUT I know that isnt true. I am willing to give up a little bit of tire wear and a slight amount of tracking but I am not willing to give up handling you guys act like its a crime to like the looks of a lowered car. I appreciate what warrtalon had to say because it was straight forward and a direct answer to my question, other peoples comments on the other hand...........
Old Feb 4, 2007 | 10:32 PM
  #34
I am highly considering doing that as well, but eventually I want rebuildable coilovers anyways cause I am not willing to spend the money on new stock struts, so I figered I might as well buy coilovers and lower the car as much as I can without negativly effecting the handling
Old Feb 5, 2007 | 08:26 AM
  #35
GTWORX.com's Avatar
My apologies, i think i did misjudge you. This question comes up a LOT, and it's usually from a certain crowd that does not honestly care about handling at all, but it seems you really do, and that's good to see.
It's a difficult question to answer, because suspension is all about compromises.
Low and soft = crappy handling, crappy ride
Low and stiff = good handling, decent ride
Very low and stiff = decently good handling, not a great ride
Very low and soft = don't even think about it
Now that i understand you better, get a dual height adjustable coilover so you can lower it a lot without sacrificing travel.
My vote is Cusco Zero 2R. With Whiteline ball joint extenders.
- Andrew
Old Feb 5, 2007 | 09:20 AM
  #36
Warrtalon's Avatar
3"? Yeah, I agree that it probably looks very nasty, but not in a good way...
Old Feb 5, 2007 | 09:28 AM
  #37
M
- Andrew
Thank you andrew for your response, its greatly appreciated. I had a friend that had the zero 2r's on his wrx and he ended up blowing them out and no one could rebuild them. One main reason that I would consider coilovers would be so I can rebuild them instead of waisting my money on new stock shocks and struts. Granted that was over a year ago when they were still relativly new. So has anything changed in the last year?
Old Feb 5, 2007 | 10:18 AM
  #38
TNTEVO9's Avatar
im in the same boat as u i have swift springs right now and i wanna go lower.
Old Feb 5, 2007 | 10:26 AM
  #39
Warrtalon's Avatar
*sad*
Old Feb 5, 2007 | 10:36 AM
  #40
porque's Avatar
For those of you looking to go lower, I'd be willing to trade my Tanabe GF210's for your Swift's.
Shoot me a PM if you're interested.
Old Feb 5, 2007 | 11:19 AM
  #41
Evo_Someday's Avatar
Actually, too low is when the control arms are below parallel
I got into this conversation late but... YES - That's the answer I would have given.
Once you go lower than that the geometry gets messed up and things start getting funky. There are fixes for that though - so you can go as low as you want. However...
My understanding of the EVO's suspension is that its travel is already relatively short (when compared to STI for example) and any additional lowering will further reduce the wheel travel.
Unfortunately, I'm not completely sure on how that affets things like dynamic camber or the results of bumpy road conditions on the car or its handeling.. perhaps someone can fill in the blanks on this subject.
EDIT: It's possible that the correct answer may end up being - you can't go any lower without some compromise in handeling or ride quality.
Old Feb 5, 2007 | 11:40 AM
  #42
rjdevo9_mr's Avatar
Originally Posted by Blue Evo 8
To each his own....
+1
Old Feb 23, 2007 | 03:58 PM
  #43
Profoxcg's Avatar
can somo one post an image of this?
Im a little confused...
"Actually, too low is when the control arms are below parallel"
What are those whiteline extenders going to do?
Old Feb 23, 2007 | 04:02 PM
  #44
Profoxcg's Avatar
Unhappy
Also, I jumped on this thread as I have my car lowered on buddy clubs but today i noticed that the front rolls a little too much for my taste... I could be my tires.. but I am running them at 32PSI (stock tires)
My front is a little lower than the back about one finger gap. and the rear has 1.5 fingers gap.
1 finger = 1/2"
  #45
4WS Tuning's Avatar
when ur friends say... daaaaaamn
too low for fat hoes!
