TEIN Mono Flex -- Feedback
Old Jun 5, 2007 | 02:18 PM
  #31
RallySport Direct's Avatar
Silver Sponsor
Originally Posted by fugiwara
does anyone know if I can order different spring rate from Tein? I kind want to stay with the stock spring rate arrangement, stiffer in the back, softer in the front.
You cannot order them from tein with different rates sorry. You have to purchase the kit and then purchase the springs you want for it.
Originally Posted by BLKLIST
TEIN USA INC. ask for Tim
9798 Firestone Blvd.
Downey, CA 90241
562-861-9161
Tim is the man but I ask him to switch them all the time and he will not do it.
Originally Posted by vboy425
junk.
Old Jun 5, 2007 | 03:28 PM
  #32
BLKLIST's Avatar
tim is the man, lol
Old Jun 5, 2007 | 06:03 PM
  #33
fugiwara's Avatar
actually I am open to any suggestions, now where can I find info/pic on this?
You may or may not care, but I figured I'd throw it out there anyway. For $1550, you can get the PIC/Pure TSOs, which are custom made coilovers that have already been setup to spec so that all you do is slap 'em on and get them aligned. Think of it as a slightly lesser version of my Vishnu/Chronohunter Ohlins but at less than half the cost...
Old Jun 5, 2007 | 06:29 PM
  #34
fugiwara's Avatar
does the MONO FLEX weigh less than stock suspension? or what is the shipping weight?
do they come pre-lowered?
thanks
Old Jun 5, 2007 | 08:02 PM
  #35
Warrtalon's Avatar
I took what I told you and put it in a search. In a few seconds, I got this:
PIC / PURE Coilovers 2nd place finish @ Evo Tuner Shootout 06'
PIC/PURE Tuning Coilover Review
Old Jun 5, 2007 | 08:58 PM
  #36
Noob4life's Avatar
and you can also give Keith or Aaron a call @ Pure Tuning if you've got any specific q's. They're on EvoM and do check in every once in a while so you can find them on here too. I can answer any questions you have regarding PIC's in general.
Old Jun 6, 2007 | 06:06 AM
  #37
BLKLIST's Avatar
thanks
They did weigh less than stock. The front stockers I shipped yesterday came in at 45 lbs on my FedEx scale. With that said I think most set ups will be a improvement in that area. My Tein FedEx tracking number showed them at 64 lbs (full set, wrenches etc...), not sure if that was a estimate or exact but it gives you and idea.
Old Jun 9, 2007 | 06:57 PM
  #38
fugiwara's Avatar
thanks BLKLIST, and Warrtalon
Old Jun 28, 2007 | 10:44 PM
  #39
Vostok 7's Avatar
The Evo comes from the factory with stiff springs in the rear. Whatever coilovers you get should also be stiffer in the rear. I don't know why Tein would swap the rates and make them 14/10. That doesn't work with how the Evo behaves. It would require lots of other changes in order to be optimized. In my case, I didn't have to touch the stock sway bars, front strut bar, or anything. It was just the coils with some bushings and rear endlinks. Simple, proper, and deadly.
I dunno about this. I've never seen stock springs OR aftermarket springs on a front engined car have stiffer springs in the front than the rear. It just doesn't make sense. Put the soft springs in the front where most of the weight is? Uh yeah... No thanks.
Anyhoo, I'm planning on getting the TEIN MONO Flex for my Evo. I had Flexes on both my last Subarus and liked them, so I'm glad to hear that the MONO Flexes are more what I am looking for.
Vostok 7
Old Jun 30, 2007 | 05:39 PM
  #40
BBS's Avatar
BBS
Vostok 7
The Evo springs are infact stiffer in the rear. Most manufacturers implement a stiffer front to induce some understeer for safety (or so I hear.)
Old Jun 30, 2007 | 06:36 PM
  #41
GTWORX.com's Avatar
Vostok 7
The springs are indeed stiffer in the rear vs. front on a stock EVO.
The front suspension is made up of struts, while the rear is a multilink set-up. This has a different motion ratio then the front struts, and require a stiffer spring for a given amount of roll resistance compared to a strut.
Imprezas have struts front and rear, EVOs do not, and thus use a stiffer rear spring even with a frontward weight bias.
As to why do most JDM coilovers come with stiffer springs up front? I'm not sure, but I don't like it.
- Andrew
Old Jul 31, 2007 | 10:55 AM
  #42
fugiwara's Avatar
both side's opinion are making sense, it's really difficult to know what is right, but I think big company like TEIN, also the pioneer in coilover, I am sure they know what they are doing, if we can go to TEIN in Japan, I am sure the Japanese technician can explain to us the reason for that.
Old Jul 31, 2007 | 10:56 AM
  #43
fugiwara's Avatar
vostok 7, did you buy the TEIN MONO FLEX yet? if so can you give me some review? thanks
Old Jul 31, 2007 | 11:17 AM
  #44
Vostok 7's Avatar
I haven't done anything yet, haven't had time to get it done, and now I'm talking to Robispec about my setup to see what would work best.
If I get the Mono FLEX I'll be sure to post a review.
Vostok 7
Old Jul 31, 2007 | 04:49 PM
  #45
nightwalker's Avatar
I've also been told to put the stiffer spring where the weight is.
