rubbing with these???
i have advan rs 18 x 9 coming in
and i have decided to get the falkenrt 615 tires in 245/40/18
will it rub? shoudl i go with a different size?
thanks,
albert
thanks,
albert
245/40's just arent that much bigger then stock. Actually the diameter is really close, since its coming from a 235/45/17 to a 245/40/18. Look it up on a tire calc.
Edit: Here is the calcs:
235/45/17 = 25.3 overall diameter
245/40/18 = 25.7 overall diameter
So very small increase in size. Actually the 255/35/18 would be a better choice, as well as wider, if you could fit it without rubbing. Thats the big question though. Next time I get new tires, Im going with 255's. I think it should be fine.
245/40 should be 21.86" and 235/45 is 21.16". I think that calculator rounds numbers off or something in the calc.
You can run 245s no problem with the +29 offset with just about any drop. S-Techs included. I personally plan to get some ADVANs as well but choose to run the 255/35 tires. They will rub a bit in back with a car load of people or hard driving from what everyone says. So I will be rolling the rears.
I researched the hell out of this over the last few months as I am saving up for some of these so trust me. Or search and see for yourself.
255/35 is my choice and depending on offset you shouldn't rub but you are very limited cause there aren't many affordable 255/35 tires...I wish they would make the RT615 in a 255/35.
sullysnet
18
Jul 31, 2019 10:39 AM
AJsGenerX
21
Mar 19, 2013 08:25 AM
oftheheavens
10
Jul 6, 2010 11:56 AM
Bizo2
22
Sep 27, 2009 09:50 PM
AmF_15
Jul 19, 2009 10:26 AM
