Rear Upper Control Arm Ball Joint
I've had a clunking noise from the right rear for a while now, and when installing my rear swaybar I noticed the ball joint boot was oozing goo, see pic. so I'm pretty sure I found my problem.
Sooo, after searching and searching and finding only two threads I thought I'd ask again.
1. Has anyone been able to replace the ball joint alone(the manual implies you need to replace the whole control arm)
2. If I do need to, how difficult is it to replace? The manual talks about some goofy ball joint removal tool.
3. Would it be worthwhile to replace either of the bushings while I'm at it? It would feel weird busting out a brand new bushing from a brand new $212 part.
I'm about to just go ahead and order one, $211.97 is not that bad, but just thought I'd see if anyone had any thoughts.
Thanks
Thanks
Part number? It looks like you are talking about the toe link (judging from the picture) and not the upper ball joint. Have you lifted the car from underneath the lower control arm (loaded suspension) and checked to see if there is ball joint play? A torn boot does not necessarily mean that it is bad. That happens when someone gets overzealous with a pickle fork among other reasons. A few more details would be helpful.
JB
JB
That has happened to my car and a couple friends too. Maybe they overfill them at the factory? Who knows, no problems here though.
The bushings on the UCA aren't really worth replacing either, the OEM ones are nice.
All right, I went and ordered it and received the control arm today and went to install the damn thing and......
Everything came apart easily enough, all nuts and bolts out in about a half hour, so the thing's all loose and floppin around, cool right. Except the ball joint shaft is stuck in the brake assembly, damn it. I whacked it pretty good, but not too hard incase I had to put her back together, which I did. I noticed that the new ball joint shaft is tapered to "wedge" into the brake assembly, so I realize its not supposed to come out easily, but it should come out.
So, my question to you all is....is there a tool I need to get that **** out of there?
Thx for any suggestions
So I just replaced my rear upper control arm. My question is this, how do I tighten the new ball joint nut, it just spins the ball joint instead of tightening. Anyone? Spanks.
Put as much force (weight) on the ball joint as you possibly can and slowly tighten the nut. Once it gets forced in there enough, the tapered portion will provide enough friction to torque the nut down.
Note you can do this when removing arms to do bushings and not cause any damage to your ball joint or the boot. Never use a pickle fork if you plan on reusing the ball joint.
If you absolutely can not get a ball joint out with the hammer on spindle method get a proper ball joint removal tool like this:
Which puts pressure on the head of the joint (ie threaded end) and the spindle. This way the ball of the joint which is under the boot is not damaged. A lot of auto part stores will rent this to you.
Hope that helps people
Thanks guys. I was able to get it all back together, thanks. The arm was around $220 shipped. I got it from http://www.trademotion.com/partlocat...?siteid=214331
That bushing is bonded in place from the factory and is used as a torsion spring. Do not think it is tight and try to brake it loose. It is designed as a torsion spring to limit travel.
Some of the Rally guys do replace with special parts but the spring rates must be adjusted to compensate. Whiteline also sells apress in poly bearing and bar but IMHO just get the stock bonded part.
Also you should be aware that they should be changed in pairs...one wears the other is not far behind...Its an Evo and it does cost to play..
Fortunately if the dust boot is just NG, you can get those from russell at Mitsubishiparts.net..very inexpensive
CrAnSwIcK
May 20, 2025 06:21 AM
jid2
Jun 1, 2017 10:30 AM
aggieEVO
Sep 21, 2015 07:03 AM
Killboy
75
Jun 18, 2014 12:18 AM
