how to remove the read brake disk?
Old Mar 12, 2007 | 09:52 PM
Profoxcg's Avatar
Can someone clue me in please?
Old Mar 12, 2007 | 10:04 PM
w evo's Avatar
if you mean the rear brake disk then you can try tapping it off with a mallet. If that doesn't work there is a threaded hole in the brake disk; just thread a bolt into the hole and that will back the disk off. I can't remember the specs on the bolt you need off of the top of my head.
Old Mar 12, 2007 | 10:21 PM
Profoxcg's Avatar
yeah the thread of that bolt is what i would like, I tryed to hit the disk and it wont come loose (the e-brake was not engaged FYI ) so i def need the bolts
Old Mar 13, 2007 | 11:52 AM
evo150's Avatar
use one of the radiator bracket bolts in one of the threaded holes in the rotors. Only brake them loose a little per side at a time. If you just try to use one bolt hole to remove them, you may strip your radiator support bolt in the rotor.
Old Mar 14, 2007 | 03:30 PM
Profoxcg's Avatar
Would you happen to know what size they are?
Old Mar 14, 2007 | 05:50 PM
Profoxcg's Avatar
which are those? do you have a pic?
Old Mar 14, 2007 | 06:48 PM
dudical26's Avatar
you can also use a bolt from the rear seat. Just unclip the bottom part and pop it off, then take out any one of the 3 screws that hold the back seat on. They work perfectly.
Old Mar 14, 2007 | 09:16 PM
Profoxcg's Avatar
would you happen to know the size?
Old Mar 14, 2007 | 09:57 PM
V.8MR's Avatar
i have never removed it on the evo, but the e-brake was integral on the STI. Make sure you have you e-brake lever down.
Old Mar 14, 2007 | 10:10 PM
ciclops04's Avatar
are you planning to use the rotor again?? If not just hitted with a hammer hard and it will break loose but if you plan to reuse hitted with a rubber mallet its tough but it works
Old Mar 15, 2007 | 12:18 AM
dudical26's Avatar
I don't remember the size but you can easily take the bolt off your rear seat in under 1 min. Its even easier than running out to a hardware store to buy a bolt
