RT-615 OWNERS, got a question
38 front and 35 rear, also on 255/40.
my car is very "rotatable" in turns like this, with my current camber settings, especially off throttle and on throttle-lift or with trailbraking.
That seems counterintuitive, since having more pressure up front would increase grip on the rears, which would induce MORE understeer than is already present. Having less grip up front especially induces understeer when lifting the throttle. We typically need more grip up front, not in the rear, but it depends on your setup.
That seems counterintuitive, since having less pressure up front would increase grip on the rears, which would induce MORE understeer than is already present. Having less grip up front especially induces understeer when lifting the throttle. We typically need more grip up front, not in the rear, but it depends on your setup.
in that case yea, it's a funny thing, isn't it but works for me. i have -1.2 front and -1 rear camber (0 toe everywhere) and i still get some tail happyness. That is assuming i don't overdrive the front tires going too fast into a turn, from which yes, i get understeer regardless.
i think your ACD catches it before it gets too loose. I, on the other hand, get that delayed reaction with VC whether i'm braking into a slide or power-oversteering at low speed with the steering cranked to the side. I believe in general the 03-04's are easier to turn in off power, but 05+ have more grip and better overall pull coming out with power applied.
32 front 35 rear for me. I like how it drives now, but might bump it up to 34f 37r and just up it from there to see how I like it. I had it at 39-42 before but I didnt like it at all. Just felt different.
when autoxing if i feel that i need help in creating oversteer i put more air in the rear or decrease in the front pending on where i'm at already.
its like when u drag race; u lower the pressure of your tires for more traction. if theres too much you wont have any traction.
im pretty much agreeing with Warr on this to be simple enough.
