Stock BBS Evo IX MR Offset
Old Mar 29, 2007 | 02:58 PM
dragmod's Avatar
What is the Stock BBS IX MR Wheel Offset?
Also, how is everyone fixing their speedo, etc...when they run larger wheels and tires?
Old Mar 30, 2007 | 09:09 AM
EvolutionBoy67's Avatar
^Off topic but what is the largest tire you can run on the IX MR wheel.
Old Mar 30, 2007 | 09:14 AM
1NastyEvo's Avatar
Been beaten to death a million times man lol. Its an 8 inch rim, you can run a 255/40/17 if you like. Or you can stick to a 245 size tire.
-Arbi
Old Mar 30, 2007 | 09:26 AM
Warrtalon's Avatar
+38 is the offset for all Evo stock rims.
I don't know anyone who has bothered to recalibrate their speedo. I have 3 sets of rims/tires, all of which are different sizes, and I don't think twice about it.
Old Mar 30, 2007 | 10:00 AM
dragmod's Avatar
I am trying to figure out offset then, and I am really confused. If i run an 18 x 9 35mm offset, why will it need spacers if I am currently running 38mm.
Old Mar 30, 2007 | 10:20 AM
Warrtalon's Avatar
Because you can't go by the offset alone. You have to go by the design and size of the rim. 18X9s are much bigger than 17X8s.
Old Mar 30, 2007 | 10:45 AM
z4k's Avatar
z4k
http://www.1010tires.com/WheelOffsetCalculator.asp
^^CHECK IT^^
Old Mar 30, 2007 | 11:55 AM
dragmod's Avatar
Originally Posted by z4k
This is awesome,
Thanks!
Old Apr 11, 2007 | 09:09 AM
Redline06's Avatar
-Arbi
This is what I was looking for thxs.. now.. tire gurus.. can I run a 255/45/17... without rubbing?
Old Apr 11, 2007 | 09:20 AM
Warrtalon's Avatar
255/45 is not right. I think you mean 255/40, and yes, that can be run without rubbing depending on the wheel and offset.
Old Nov 24, 2007 | 03:58 PM
evox7's Avatar
I just got some Axis Hiros all black for my Evo 9 SE they are 18x8.5 +35 offset. How much more will this Stick out over the stock SE BBS wheels? Should I go wider?
Old Nov 30, 2007 | 06:54 PM
EVO8emUp's Avatar
Plus the offset will change depending on width.
Old Dec 7, 2007 | 06:08 PM
mrfred's Avatar
There's more to it than just the offset of the rim. Tire width matters as well.
Old Feb 28, 2008 | 12:00 PM
S1MPSONS's Avatar
Back from the dead. Are you all sure the width of the MR BBS's is only 8", not 8.5? What is weight?
Old Feb 28, 2008 | 12:06 PM
Kracka's Avatar
MR/SE BBS wheels are 18x8 +38 and weigh 17 lbs.
