Wheel Fitment PICTURES ONLY Thread
#82
wheels: TDR Race Pro 1.2 18x9, 35mm offset, 5mm spacer in front.
tires: 265/35ZR18 tires.
fenders: Rear fenders were rolled to accomodate the
suspension: front: -1.8* camber, 0 toe rear: -1.5* camber, 0 toe. stock suspension
Weight is 20.5 lbs per rim.
#84
OWNER: MR06Evo
Wheels: 18x9.5 work emotion cr kai +30 Spacers-Kicks 10mm front spacer with extended studs...
Tires: 255/35/18 Pirelli p zero nero m+S
Fenders: None but I'm going to roll the rears because it rubs on bumps when i have more then 3 people in the car.
Suspension: Oh and im dropped on bc racing coilovers
#86
owner: Me/SilverShadow03
wheels: ROTA SVN 18 x 9
offset: + 30
tires: FALKEN AZENIS RT 615 - 245/40/18
fenders: Front OK, Rear requires fender rolling w/current height setting (rubs w/intense cornering or 3 + passengers - OK normal driving).
suspension: TEIN SS Coilovers
offset: + 30
#89
Owner: Pesky
Winter Wheels: Enkei RS6 17x7 38mm offset w/ optional red center caps
Tires: 215/50R17 Yokohama AS430
Fenders: Stock
Suspension: Stock
Note: Use stubby valve stems or the wheels will not clear the calipers.
Pesky
St. Louis
Fenders: Stock
Suspension: Stock
Pesky
St. Louis
Last edited by Pesky; Oct 7, 2007 at 09:15 PM. Reason: Upload pictures instead of link them.
#90
Wheels: Wedsport SA-70 (17 x 9 + 35) Light Grey (Gray)
No spacers, but require plastic centering rings (from the Tire Rack)
Tires: Nitto NT-01's or Toyo RA-1's (255/40/17)
Suspension: Stock MR Bilstein. Camber -1.9 -2.0 (max with stock set up)
Currently working on custom made (aluminum) centering rings to replace the crappy plastic. For track use, these plastic Gorilla’s last for one event before the heat annihilates them into oblivion.
