brake clunk
Old Apr 2, 2007 | 07:39 PM
05silevo's Avatar
brake clunk
I just installed front and rear pads and now when I am coming to a stop I get a click sound from the rear brakes. It only happens once when I kit the pedal. Any suggestions on the problem?
Old Apr 2, 2007 | 07:42 PM
IX stealth MR's Avatar
Like when you press down on the petal once it hits the friction point, it makes a click noise?
Old Apr 3, 2007 | 09:21 PM
05silevo's Avatar
yeah when I press the pedal it seems to click once the fluid get moving. Just one click though until you release the brakes and drive for a bit.
Old Apr 8, 2007 | 09:12 AM
karlzhot's Avatar
bump! i'm having the same problem
Old Apr 8, 2007 | 09:14 AM
Curt@MrLed's Avatar
Former Vendor
sure the caliper is tight.. were the metal pins worn, are there metal plates on the pads, are they on right...
Old Apr 8, 2007 | 09:20 AM
karlzhot's Avatar
Mine started like i want to say 8 to 9 months after installing brake pads. I checked and nothing is loose. It's only when i come to a slow stop. I hear the clunk like something is engaging or disengaging.
Old Apr 8, 2007 | 09:21 PM
ghoonk's Avatar
I have the same problem after 3 track days. Subscribing to keep an eye out for responses
Old Apr 8, 2007 | 10:43 PM
evo8mr_bobby's Avatar
ya have got pad shuffle,there just moving in the callipers, very common with the brembo's depending on what pads ya have fitted and nothing ya can do to stop it. mine does it in reverse big clunk for the 1st press of the brake pedal and then a small clunk for the 1st press when goinf forward. then it stops. hope this helps
Old Apr 9, 2007 | 08:12 PM
bhamEVOguy's Avatar
mine does it too. i thought it was normal.haha
Old May 22, 2007 | 12:57 PM
karlzhot's Avatar
bump for this....
Old May 26, 2009 | 05:59 AM
Timujin's Avatar
Holy old posts.
My car does this too.
Old Jul 15, 2009 | 03:14 PM
koolaidesi's Avatar
Bump:
Mine too just started doing this. I go slowly forward and step on the brake and it makes a noticable THUNK.
I just put on RotorPro blanks and Racing Brake ET500s fed with Techna-fit lines and shortly after an autox, it began doing it. Performance doesn't seem to be hampered one bit; still stops very crisply, just makes that noise.
