View Poll Results: is the rotor on right, or should it be on the other side
They're right, you're a guru.
15
71.43%
no, you F***'** idiot.
28.57%
Voters: 21. You may not vote on this poll
slotted rotors on backwards?
Old Apr 3, 2007 | 11:05 PM
4WS Tuning's Avatar
a friend said these are on backwards.... are they?
there were little stickers on them, right and left...
im gonna be pissed if i have to redo them...
thank you!
Old Apr 3, 2007 | 11:10 PM
AmF_15's Avatar
They are on right. (as far as in the pic) looks nice btw
Old Apr 3, 2007 | 11:12 PM
ApexVIII's Avatar
different rotors have different rotation directions. if thats how it said to do it then its right
Old Apr 3, 2007 | 11:14 PM
4WS Tuning's Avatar
thank you, theyre dba 4000...
i followed the sticker directions.. but from some1 much more experienced in brakes said theyre suppose to be opposite
Old Apr 3, 2007 | 11:22 PM
andenbre's Avatar
looks good to me, i dont think it really matters though unless the mfr specifies. benz uses brembo for their performance brake hardware and they have no pref considering its the same part for left and right even on the the SL65's
Old Apr 3, 2007 | 11:23 PM
newimportowner's Avatar
They sure look right to me.
Old Apr 3, 2007 | 11:28 PM
evrblazin's Avatar
yea they are on right... your calipers are looking good
Old Apr 3, 2007 | 11:31 PM
Apex Racer's Avatar
Different companys have different set ups, my powerslots go the opposite direction. As long as you followed the directions you are good.
Old Apr 3, 2007 | 11:33 PM
holyfrickster's Avatar
True different companies could have different rotation. :-) Nice rotors by the way
Old Apr 4, 2007 | 12:59 AM
SinGin's Avatar
It depends on the manufacturer. You should consider adding that as a third choice. My Rotoras go the same way. The slot sweeps the pad inside out.
Last edited by SinGin; Apr 4, 2007 at 09:31 AM. Reason: sleep induced mistake at 1am
Old Apr 4, 2007 | 01:08 AM
DoctorEvo's Avatar
DBA have the slots in their rotors this way to 'minimise' brake dust. They market their discs as 'racing' products, but know that the majority of their product will end up on road cars. I run the DBA5000 discs, but I installed them back-to-front, so the slots are facing the other way... this gives slightly more 'bite', at the expense of pad life, and resulting in plenty of brake dust. Your friend's suggestion is not without merit, but it's really about what you want out of your brakes....
Old Apr 4, 2007 | 03:44 AM
WarmPepsi's Avatar
the real question, is why you pulled your suspension, to install a rotor.
The rotor should take air from the inside of the hub (rotor) and pump it out through the veins during use. Think of which way the wheel is spinning, and which way the air moves out of the veins.
That tells you which way they need to go, however, the slotting looks right.
Old Apr 4, 2007 | 03:45 AM
AndyBandy's Avatar
they look fine
Old Apr 4, 2007 | 04:16 AM
dadriva's Avatar
Correct! It does not matter how the slots look. It matters how the veins are oriented. They should be oriented to let the hot air out.
I have Racing Brake's slotted rotors and the slots are oriented (correctly) in the opposite direction from the OP.
Remember, brakes are there to stop your car quickly and efficiently, not necessarily look good.
Old Apr 4, 2007 | 04:39 AM
rlui0514's Avatar
