View Poll Results: is the rotor on right, or should it be on the other side
They're right, you're a guru.
15
71.43%
no, you F***'** idiot.
28.57%
Voters: 21. You may not vote on this poll
slotted rotors on backwards?
Old Apr 4, 2007 | 07:06 AM
4WS Tuning's Avatar
Originally Posted by WarmPepsi
the real question, is why you pulled your suspension, to install a rotor.
The rotor should take air from the inside of the hub (rotor) and pump it out through the veins during use. Think of which way the wheel is spinning, and which way the air moves out of the veins.
That tells you which way they need to go, however, the slotting looks right.
wait you're saying i didnt need to do that? god damnit!
jp lol.... i did suspension and brakes at the same time... nailed the brakes then i moved to springs..
Old Apr 4, 2007 | 07:07 AM
4WS Tuning's Avatar
Originally Posted by holyfrickster
True different companies could have different rotation. :-) Nice rotors by the way
thank you sir!
Old Apr 4, 2007 | 01:15 PM
rsboy's Avatar
My slotted rotors had Front Right and Front left on them... so the dilemma was...
does front left mean driver's left side when in driving position or when facing the vehicle head on...
my mechanic friend said it's the driver's position... so we installed it that way. The slots on mine face the opposite of the original poster's rotors.
Old Apr 4, 2007 | 01:18 PM
WarmPepsi's Avatar
yeah, the battery is next to the front left wheel. it's drivers, or path of motion position.
Old Apr 4, 2007 | 01:19 PM
ROAD RACE VR-4's Avatar
I used to have a set of Baer brakes and the slots were the other way. Each manufacturer has their own way of setting them up.
Old Apr 4, 2007 | 01:43 PM
dudical26's Avatar
you want the internal slots to allow air to come in to the center of the rotor and push the air out. The slots inside you be angled in the opposite direction of the spin direction.
Old Apr 4, 2007 | 02:12 PM
4WS Tuning's Avatar
thats where the confusion was... i was told they should be the other way, and the way he explained them it made sense..
Old Apr 4, 2007 | 02:52 PM
DoctorEvo's Avatar
It pays to remember that the DBA discs DON'T have internal slots / vanes.
They use their patented 'Kangaroo Paw' design for internal ventilation... this doesn't work in the same way tha ttraditional cooling vanes do...
http://www.dba.com.au/2006/videoclip.asp
Old Apr 5, 2007 | 12:34 PM
homiusang's Avatar
Looks good. Brembo already peeled on your 06 IX?
Old Apr 5, 2007 | 12:45 PM
xxxevo8xxx's Avatar
If those are Brembo then they are backwards. It shows them to go the other way in the directions.
Old Apr 5, 2007 | 04:51 PM
dubbleugly01's Avatar
yes, it's more important that the rotor vanes are working properly than to worry about the slots in the rotors. Lots of good info. in this thread about it.
https://www.evolutionm.net/forums/sh...d.php?t=205273
WhiteHat
47
Dec 16, 2018 07:19 PM
tuner
18
Feb 28, 2006 04:16 PM
mr0072003
Feb 3, 2005 11:09 PM
6one9EVO
Sep 16, 2004 10:08 PM
Hedonic Tread
Jun 7, 2003 01:45 AM
