Forge RS BOV Mounting
Old Feb 14, 2006 | 08:02 PM
tuner's Avatar
Ok, I bought a Forge RS to use with my GT30 turbo installation and am ready to mount it. I noticed that if I mount it in the regular position that the top of it will push up into the radiator hose by quite a ways. How do most people mount them? I sent a PM to Mike at Forge but got no response. I know some have mounted the regular Forge BOV backwards; it looks like if I mount the RS backwards that I will have plenty of room. Should I do that? Any help appreciated.
Old Feb 14, 2006 | 08:06 PM
Warrtalon's Avatar
Are you sure you aren't already doing it backwards? The ratchet knob should be point sideways, not straight up. The "top" should be horizontal, so it shouldn't mess with the radiator hose unless you have a special intake pipe that throws everything off.
Old Feb 14, 2006 | 08:12 PM
gaulrich2003's Avatar
not to sure, trying to figure it out myself.
Old Feb 14, 2006 | 08:21 PM
Warrtalon's Avatar
Originally Posted by gaulrich2003
make sure it isn't backwards. The BOV sits up like a bottle without spilling the liquid. The part u tighten would be like the lid of the bottle. You should be able to see the small word forge not the larger word forge when u look straight down. If u turn toward the plus side it will prevent the Boost from dropping. Hope this helps!!
??? Are you sure YOURS is not backwards, too? Maybe I didn't understand the bottle reference, but the "top" should be sideways, not pointing up.
Like this:
Here it is hidden beneath the radiator hose with no clearance issues:
Old Feb 14, 2006 | 08:31 PM
thanks!
Old Feb 14, 2006 | 08:34 PM
Warrtalon's Avatar
My car looks different than that under the hood. I know it isn't backwards because I already put it on backwards and my car wouldn't run! It looks like the BOV in the first picture is set to atmospheric.
Your car looks different? That first pic is just with the entire intake removed while we were installing the ported/coated stuff. That's why it looks like VTA, I guess, haha. You can see, though, that the bottom outlet of the BOV is pointing directly to where the intake hole is in the stock, rubber MAF pipe. That's how yours should look. Your car should also not fail to run just because you put the BOV on backwards. I think you may have made a mistake somewhere during your installation.
Old Feb 14, 2006 | 08:36 PM
Evo05lution's Avatar
wow your an idiot if u can observe u will see warr didnt have the intake tube connected to the turbo...
Old Feb 14, 2006 | 08:40 PM
I appreciate the comment!
Old Feb 14, 2006 | 08:48 PM
I appreciate the comment pencil dick!
no problem, and great comment on your part...how much thinking u put into it?
Old Feb 14, 2006 | 08:56 PM
The thought process? I do not appreciate the idiot comment on here, it is just look you said to my face. I do not take those kind of things lightly. Next time try to think about what your posting about a complete stranger.
I heard they are going to add a section on the ACT about BOV installation.
Old Feb 14, 2006 | 09:00 PM
Warrtalon's Avatar
Gaulrich, concentrate on fixing your BOV installation. I'm certain you have yours backwards...
Old Feb 14, 2006 | 09:08 PM
I will switch it back to the way I had it before.
Old Feb 22, 2006 | 04:50 PM
tuner's Avatar
Mounting Forge RS BOV
OK, duh - now I get it thanks to Warrthalon's photos. The Forge RS mounts sideways and fits perfectly. I had the pressure/suction piping backwards in my mind. Thanks for the help Warrthalon.
Old Feb 22, 2006 | 05:00 PM
Anarchy99's Avatar
Like this:
This is how the valve should be mounted there should be no need to mount it anyother way.
Old Feb 22, 2006 | 05:08 PM
taenaive's Avatar
you can't mount the new forge RS BOV backwards. you could do that on old ones.
you have to be bit creative here. I would buy an pipe that is the same size as the bov outlet and a turbo hose that fits the pipe. then put the pipe into the intake and connect the bov between your UICP and the pipe.
Or, you can do what I did. get a heat wrap or thermal tapes. Then, just wrap around the BOV.
edit: buy the L shaped pipe
