Alignment Q&A
Old Apr 10, 2007 | 08:11 PM
Truevolution's Avatar
Alignment Q&A
I was running 205 50 17 snows on 17X7 rims. Just put on my stock summers and rims and had an alignment. Car feels a little jittery, I know advans have supper stiff sidewalls and that they find every rut in the road...Keeping that in mind let me know what you think of my specs for alignment?? Thanks
Left front:
camber before -1.17 degree actual is -0.97 degree
caster before 3.34 degree actual is 3.34 degree
toe before -0.13 degree actual is 0.01 degree
Right front:
camber before -0.58 degree actual is -0.66 degree
caster before 3.23 degree actual is 3.23 degree
toe before -0.15 degree actual is 0.01 degree
Front:
Cross camber before -0.59 degree actual is -0.31 degree
Cross caster before 0.11 degree actual is 0.11 degree
Total toe before -0.28 degree actual is 0.02 degree
Left rear:
camber before -1.19 degree actual -1.2 degree
toe before -0.15 degree actual 0.14 degree
Right Rear:
camber before -0.75 degree actual -0.95 degree
toe before 0.03 degree actual 0.18 degree
Rear:
Total Toe before -0.12 degree actual 0.32 degree
Thrust angle before -0.09 degree actual -0.02 degree
Old Apr 10, 2007 | 08:20 PM
Warrtalon's Avatar
I'm not sure what all that means. When you say "actual," do you mean "after"? Are these showing your before and after settings? If so, then...
1) Why is the front camber not the same?
2) Why is the front camber so minimal?
3) Why is the rear camber not the same?
4) Why is the rear camber more aggressive than the front camber?
5) Why is the rear toe so extreme? It should be set to 0.00.
Old Apr 10, 2007 | 08:30 PM
hondafan's Avatar
+5. whoever did your alignment did a bad job. my dealer matches everything perfect on both sides.
Old Apr 10, 2007 | 08:43 PM
evo8426's Avatar
have them set it back to spec
Old Apr 11, 2007 | 05:56 PM
Td5turbo's Avatar
^yea, thats should do the trick
Old Apr 11, 2007 | 08:39 PM
JohnBradley's Avatar
I would bet factory cam bolts with factory suspension, that variance is common in all the Evo's I have aligned
Again common with stock suspension, I have yet to see one on spec with the cam bolts set to -1.0*
No excuses for that one, I agree
Rear spec is -1.0* according to Hunter (as per the machine spec and SPC's alignment spec book) The fact that it uses the word "cross" camber is the giveaway on that one.
Factory is .24* total toe (per spec) with a variance of +/- .-8*. So technically its within spec even though we both know that in reality it should be zero.
Old Apr 11, 2007 | 08:47 PM
lightspeed1's Avatar
FYI...the reason that the camber specs are not the same is because of "manfacuture's recommended specified range". Basically local shops/tire stores typically adjust within the "ranges" that are specified as "OK" by Mitsubishi. If you ask before hand that you want each side to match (camber/caster/toe) then they will do so..(they might be a little pissed, but they will).
Old Apr 11, 2007 | 08:51 PM
Warrtalon's Avatar
I guess I'm a little confused, because when I get aligned, I tell them exactly where to put it, and that's what they do. On stock suspension, I got -2.0/-1.9 up front and -0.5 rear with 0 toe all around. It wasn't a problem.
Now, I have coilovers and camber plates, so it's really easy, but the shop I go to didn't seem to have a problem hitting the mark when stock either.
Old Apr 11, 2007 | 09:39 PM
uglyevo's Avatar
most places you go all the guys there are alignment noobs and give excuses as to why they couldn't meet your specific needs. At least that is what I have come across so far
