Looking for suspension
Old Apr 21, 2007 | 10:02 PM
EvilEvo999's Avatar
Need some suggestions !! Im looking for a set of aftermarket suspensions but dont want to spend too much money on it. Planning to get the tein basic. Does anyone used that or any others ? Hope to hear some suggestions. thanks
Old Apr 21, 2007 | 10:15 PM
chaotichoax's Avatar
the suspension forum would probably be a good start
pm a mod and have the thread moved there
more likely to get detailed answers
Old Apr 22, 2007 | 12:07 AM
belizelittle39439's Avatar
There's a couple things you should ask yourself before going with a suspension setup....
1. How is you car going to be used? A new suspension for a daily driver wouldn't make much sense unless you're looking for something softer than stock; on the other hand a more adjustable suspension with higher spring rates would be useful if you're going to track the car.
2. Whats your exact budget? This will often limit your options and help to minimize the dilemma of trying to figure out which of the 100 brand names you should buy.
You can always contact Robi on the forums here...you will get good advice. Or you can just paruse the suspension forum for a while. Learn and you can make the decision for yourself.
Old Apr 22, 2007 | 01:40 AM
EvilEvo999's Avatar
Im just looking for daily driving use more softer. What you guys suggest ?
Old Apr 22, 2007 | 07:52 AM
Well...
Here's some info then taken from THIS thread:
Stock(USDM):..........180lbs(3.2k)....225lbs(4.0k) ......STOCK
Tein Basic:...............392lbs(7.0k).....336lbs(6.0K) ....Adjustable
So even with your Tien basics you'll have a bit of a higher spring rate. IF the adjustability is such that you can minimize the dampening to a softer rate than it shouldn't be noticeable. Call the manufacturer first.
Old Apr 23, 2007 | 02:19 AM
space's Avatar
softer? evo stock is not a hard ride surely?
Old Apr 23, 2007 | 04:01 AM
Jdav79's Avatar
Go for a set of Megan Racing Coilovers. There is a member here who can get them at a killer deal, I think maybe Zeus.
These coilovers are getting amazing reviews from eveyone who has them and they are not really expensive. (Springs & struts/shocks for less than $900)
Old Apr 23, 2007 | 09:03 PM
el producto's Avatar
Megan and K sport are pretty cheap...
Spring rates are very important when picking your coilovers, I know people who run autocross with 12k front 10k rear and its obviously going to be a rougher ride but the handling is unbelieveable so I duno you should just keep stock suspension if you want the softest....
Old Apr 25, 2007 | 04:34 PM
srtfourplay's Avatar
Hot bits.
Old Apr 25, 2007 | 04:42 PM
gsrboi80's Avatar
BC Racing around 1G and an excellent street coilover. Check evom homepage.
If not get the Megans. Which are made by BC anyway
Old Apr 25, 2007 | 05:36 PM
hondafan's Avatar
anyone out there try the greddy coilovers? heard they aren't too harsh.
