Improved Wheel Fitment Confirmation Thread(sticky Me)
This is my first contribution to EvolutionM.net, hope it's found to be a valid one!
Noticed there is one of these already in the sticky section. Unfortunately, the original poster's idea got overtaken by people asking questions, and no one posting thier own information. This thread should only be used to reference, not a Q & A session. If you do not find the wheel you are looking for in this thread, then please post a new thread asking your question. HOWEVER!! Please add to this list. Add your own current aftermarket wheels, as well as thier specs, you can even add your buddies, friends, enemies, grandparents, whoever's specs..as long as they are CONFIRMED TO FIT, as that is the whole idea behind starting this. Please double check each one of the following wheels with tire rack to see what is required (usually tuner style lug nuts, and sometimes a ring) they can be found under installation notes. Enjoi!
Wheeel: Size: Offset(+): Weight(lbs):
Enkei RS-5 17x7 40 n/a
Enkei GTC01 17x8.5 35 19.5
18x8.5 30 22.0
Enkei RP03 17x8.5 30 n/a
18x8.5 30 n/a
Enkei RPF1 17x8 35 14.5
17x8.5 30 16.5
18x8.5 30 19.0
Gram Light 57C 18x8.5 30 21.0
Gram Light 57F 17x8.5 30 n/a
18x8.5 30 n/a
Gram Light 57Maximum 17x8 33 18.5
18x8.5 33 n/a
Gram Light 57Optimise 17x8.5 30 19.5
18x8.5 30 n/a
Gram Light 57S 17x8.5 30 n/a
18x8.5 30 21.5
Gram Light T57 17x8 33 n/a
18x8.5 33 21.8
Kazera KZ-F 18x9 33 25.5
Kosei K1 TS 17x8 35 15.5
Kosei K3 18x8.5 30 20.8
OZ Canova 18x8 35 28.5
OZ Crono HT 18x8 35 19.5
OZ Superleggera III 18x9 41 25.4
OZ Ultraleggera 18x8 35 18.4
18x9 35 20.8
RO_JA R2-5 18X8 33 23.6
RO_JA R2-7 18X8.5 33 24.2
SSR Competition 18x8.5 32 17.2
SSR GT3 18X9 44 25.1
Volk RE30 18x8.3 30 17.5
Volk TE37 18x8.5 30 18.5
Wedsport SA-70 17x8 32 17.0
17x9 35 17.8
18x8 40 19.0
18x9 32 19.8
18x8.5 30 22.0
18x8.5 30 n/a
17x8.5 30 16.5
18x8.5 30 19.0
18x8.5 30 n/a
18x8.5 33 n/a
18x8.5 30 n/a
18x8.5 30 21.5
18x8.5 33 21.8
18x9 35 20.8
17x9 35 17.8
18x8 40 19.0
18x9 32 19.8
uhh...I had all the info spaced out in columns so it was easy to read, not sure what happened here? Someone know how to clean this up a lil bit, so it will actually show up in columns?
This really doesn't tell you anything unless you have tire size on there.
You can run a really wide wheel if you stretch the hell out of the tire.
Is this thread supposed to tell us which wheel fits over the caliper? If so, offset is irrelevant and it's simply the spoke design and thickness of the mounting surface of the center.
