TE37's needs some rubber
Old May 17, 2007 | 07:31 PM
gearslaper's Avatar
Hi guys
I have a question:
I purchased some new wheels for my ride (TE37 18X9.5 +35) and I need some advice on selecting the right tire. I want to go 255 X 35 X 18, but I am not sure which tire would give me the best ride. These tires will only be used for the summer months, so grip is important.
I will track the car a few times this summer, but mostly will be street driven.
Any advice would be helpfull
Thanks in advance
Old May 17, 2007 | 07:35 PM
555R's Avatar
hmmm
grip and ride dont always go together
i used to run advan AO32Rs in the hard compound daily for summer use
but it wasnt a great ride and it was noisy as hell
i would drive pretty much weekends and then to and from the road course and then home again
Old May 17, 2007 | 08:00 PM
gearslaper's Avatar
What if I bumped up to these?
Falken Azenis RT-615
265/35R-18 93W OWL
whadda you think?
Old May 18, 2007 | 01:24 AM
IfDontFITsPIT's Avatar
I think you are going to rub pretty hard with 265... the 255 you might also run but with the 35 offset you may get away with it...
Old May 18, 2007 | 01:40 AM
TeKiZeRo's Avatar
I just bought the Falken FK452 255/35/18 for my new setup. I did a search on those tires and they had positive feedback on the forums.
Old May 18, 2007 | 06:45 AM
gearslaper's Avatar
thanks for the response
Old May 18, 2007 | 09:27 AM
EvoPooPoo's Avatar
You can't beat the grip of R compound tires... but they need to warm up.
Sidewall is what will ultimately determine the comfort...but most tires at 255/35/18 will be pretty stiff.
You can run 265's up front and 255 on the rears with your offset. You should be able to get away without any issues.
if any rubbing add slight negative camber. This will also give you stability in the turns.
good luck.
Old May 18, 2007 | 09:37 AM
Neal@tirerack's Avatar
265's are a bit much, you may want to stick with the 255 at most. Only know a few around here running that size though.
B-Stone RE-01R is the closest thing to a street comp tire you can get. Pure dry grip and steering response. Can be a little over kill if you're not beating the car every day...maybe you are I dunno The Yoko Advan Sport would also be a good choice. Similar grip but a little better life.
Old May 18, 2007 | 09:20 PM
gearslaper's Avatar
Thank you again for the good advice -)
Cheers
Old May 18, 2007 | 11:44 PM
555R's Avatar
i didnt think you can run different tire sizes and not hurt the acd
different outside diameters front and rear
i dont know of anyone doing that on this forum
search and i think t here are posts regarding this
polish_pounder
Nov 6, 2014 01:41 PM
Mikeodeth
May 5, 2014 04:00 PM
holydang
Mar 25, 2014 09:10 AM
lookitznite
10
Nov 15, 2011 06:32 PM
blue-gsr
10
Nov 4, 2009 05:21 PM
