Brake pads and rotor question
Old May 19, 2007 | 01:57 PM
masterbetter's Avatar
I read somewhere on the forum that its best to install new pads first and to break them in before installing rotors. What are the disadvantages if I break in new pads on brand new slotted rotors?
Old May 19, 2007 | 04:53 PM
ustcc evo's Avatar
You should break in the pads and rotors together.
Old May 19, 2007 | 05:00 PM
pao's Avatar
pao
No disadvantages whatsoever. Matter of fact it's preferred.
Where ever you read that it's "best to install new pads first and to break them in before installing rotors" is incorrect.
What you want is to have the new pads conform to the new rotors w/o having to do away with the old brake pad surface. This is also why you resurface your rotors every time you change brake pads. Think about it. If you break in the new pads on your old rotors (assuming you're going to change rotors) you'll be grooving out the new pads to whatever the old rotors surface is and cause more wear & tear on both components initially.
Hope this helps & makes sense.
Old May 19, 2007 | 08:10 PM
EVO X Owner-2-B's Avatar
Read up, guys ... https://www.evolutionm.net/forums/sh...ad.php?t=81487
Old May 20, 2007 | 09:30 AM
WarmPepsi's Avatar
yeah, and get rid of the myth that "slotted is better".
slotted is junk. unless you have a PHAT wallet.
Normal flat rotors are fine.
Old May 22, 2007 | 05:10 AM
Adamk24's Avatar
Go with aftermarket units at the best price, the stock ones are so expensive for what you get...
WWJPD
Aug 12, 2013 07:31 PM
Chaz17
12
Dec 8, 2011 08:49 AM
Piro Fyre
23
May 15, 2010 12:34 PM
evolutioner27
10
Mar 20, 2010 04:51 PM
Ariofighter
Apr 30, 2006 10:54 AM
