Hotchkis question...
Old May 29, 2007 | 11:14 AM
j14mp's Avatar
i just got some hotchkis springs... but im concerned about how badly it gonna hurt performance. this year im only gonna be doing drag.. wanted coil overs but i decided im gonna spend the money on an fpgreen..... next year i plan on getting coil overs but for the time being i NEED a drop... honestly im like insecure about stock height hahaha
so my question in.. how bad will the performance of my evo be affected by installing these springs?
EDIT: i did search but i couldnt find a direct answer.. especially from people that own them
Old May 29, 2007 | 12:22 PM
boomn29's Avatar
imo - Hotchkis springs aren't the best, but they certainly aren't the worst.
If you're not tracking the car, and don't do a lot of aggressive driving, I'm not sure how much you'll notice the change. How much do they lower the car? Do you utilize the factory bumpstops? The latter being a big question for spring imo.
Don't throw on spring that'll lower your car 2" in front and expect a smooth ride. There are some springs that lower > 2" that some people do for show/garage queens and they don't care about the ride - so keep that in mind.
A lot of the performance (Espiler GT, Works, Swift, Gtworx) springs utilize the factory bumpstops and lower 20-35mm front which is about 1-1.5" max. FYI.
Old May 29, 2007 | 01:27 PM
j14mp's Avatar
well im def not for show ... but theres something about stock height that gets to me haha
im not tooo concerned about the rough ride considering its not my daily driver. the springs
they include poly urathane bump stops, 1.5" Drop 195lb/in (200lb/in Stock)Rear 1" Drop 275lb/in (270lb/in Stock)Suggested Alignment SpecsFrontToe: 0-.05 toe outCamber: Maxed out the camber on the front should be close to -2RearToe: .25 total toe inCamber: -1.15
not sure if that helps at all... ill be ok if they are DRAMITCALLY worse then stock... i WILL have coil overs before i autocross it though...
Old May 30, 2007 | 02:56 PM
j14mp's Avatar
anyone else have any input by any chance? still not sure if i wanna install them...
WS111
May 5, 2014 05:36 AM
gotboostawd
19
Apr 3, 2009 09:00 PM
j14mp
Dec 25, 2007 06:26 PM
IVERSON3270
Sep 23, 2007 01:07 PM
jkim1201
Oct 18, 2006 08:14 AM
